Latest post 05-08-2007 5:38 PM by Kevin. 20 replies.
Page 1 of 1 (21 items)
  • 05-06-2007 10:47 AM
    More help please!
    Getting slightly embarrased now! but I am in need of more help!
    I have bought a new lamp but I do not know which bulb is needed!! Photo as below:
    Anyone know? the lamp is a Louis Poulsen Panthella, have sent them an email but no answer as yet.
    TIA!
  • 05-06-2007 10:58 AM In reply to
    Re: More help please!
    That looks like an energy saving fluorescent type fitting. We use those at the surgery. The problem is that you need exactly the right one as the position of the two contacts varies from bulb to bulb. Doesn't it have a type on the base?
  • 05-06-2007 11:01 AM In reply to
    U just need an E 27 type bulb with 150W/m.
    See the the following link:
    http://www.louis-poulsen.com/products/configurator.asp?kmatnr=000000000000090386&Lang=in&cat=32
    HTH.
    Pedro "Less is more"
    BV7-40 MKII + BL7.2 + BL9 + BL3 + BS4 + BL4 + A9 + Earset 2 + 2 x Beo4 + BeoCom 5
  • 05-06-2007 11:07 AM In reply to
    Thanks! I tried the site but cannot find anything matching thier codes on the internet...
    Found this site:
    http://www.lightbulbs-direct.com/variant_detail.asp?var=3308
    This looks like it... as the holder looks pretty standard...
    Look at this page for some clues!
  • 05-06-2007 11:10 AM In reply to
    mobeyone:
    Found this site:
    Ah! There speaks the voice of the young! Unfortunately the pin position varies so you can only put the correctly rated bulb in each fitting! We have three different sorts of bulb at the surgery. They all look identical to the untutored eye!  And you always pick up the wrong one when they need replacing and wonder why they won't fit!
  • 05-06-2007 11:14 AM In reply to
    Brings new meaning to the old joke that is changing a light bulb!!!!!! How hard can it be!!
    Well, I am going to order one of each of the G24s!! They have the slots on the side which mirror the inside of the holder.. well i think anyway!!!
    Thanks again!
  • 05-06-2007 11:29 AM In reply to
    I would go to the local B&Q and have a look! Make a template of the lamp socket - you can have one tomorrow then!
  • 05-06-2007 3:21 PM In reply to
    • Graeme
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Aberdeenshire Scotland
    • Posts 194
    http://www.light11.com/Mood_lighting_for_side_tables.326/Panthella_T.58.html
    is this the lamp Mobe? gives the bulb type in the spec
    Hope this helps
    Graeme
    Cheers Graeme
  • 05-06-2007 4:13 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    When Mobe first posted this thread I looked it up on the web. Got the same bulb as you Graeme, Do not think it is correct though. That will not fit the Bulb Holder in Mobe's picture. Not that I can see.
    CraigBig Smile
  • 05-06-2007 11:21 PM In reply to
    • stevo4
    • Joined on 04-17-2007
    • Los Angeles
    • Posts 82
    I don't know if this helps, but i wear Pantherella socks! Big Smile
    stevo
  • 05-07-2007 1:50 AM In reply to
    stevo4:
    stevo
     Then you must have to be careful with static elctric charges. (Perhaps you don´t need to cut the nails of the feet, it would be an advantage) Laughing
    Rafa
  • 05-07-2007 7:53 AM In reply to
    Graeme:
    Hope this helps
    Graeme
    Yes but I have the floor lamp which is just a little bigger!
    Craig is right again - just went to B&Q... and bought the wrong one!!!!!!!!!! So off I go again! I even picked the right one up first but put it back thinking it was too big!!! DOH!
  • 05-07-2007 1:56 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    This is the forteenth post on this threadSurprise
    Talk about "Many hands make light work"Laughing
    Hope you've got it sorted now, Mobe.
    Andy T.
    Poor me, never win owt!
  • 05-07-2007 5:46 PM In reply to
    Certainly have Andy!!
    The lamp is gleaming in all its glory now! How complicated is this green business!
  • 05-07-2007 5:48 PM In reply to
    So how many Beoworlders does it take to change a lightbulb? Laughing
  • 05-07-2007 6:12 PM In reply to
    • 9 LEE
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Peter:
    Let's have a Poll and find out!
    LaughingLaughingLaughingLaughingLaughingLaughing
  • 05-08-2007 3:00 AM In reply to
    • Puncher
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    I take it from all this that Mobe won't be a very frequent contributer to the proposed new Techy forum WinkBig Smile
  • 05-08-2007 5:37 AM In reply to
    Puncher:
    Certainly seems to be the case!!!!
    Cant believe I posted a thread about a lightbulb LOL!!
    Must be my youthCool
  • 05-08-2007 4:42 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Blimey Mobe - I bet you're the only bloke I know who's actually looking forward to a return to the dark agesLaughingLaughing
    Chris.
  • 05-08-2007 5:38 PM In reply to
    • Kevin
    • Top 50 Contributor
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    What's wrong with candles? That's what I say!Stick out tongueCool
