ok here goes
a 'friend' of mine has strayed down the path of wiring several rooms of his house with the intention of putting BOSE in. Having seen what B&O stuff can do he wants B&O in the several rooms he has expensively wired already. Each room has at least a pair of passive speaker cables going back to one point in the room (where normally he would have a BOSE sub). At this same point he has BOSE-LINK cable going to the next room, as well as CAT5 and 2 x CT100 and so on.
Still with me?
What I think we can do is this:
Output from a BeoCenter 2 as his Master. Link several active kits so he can have B&O speakers in each room, replacing the passive cables with powerlink. In the same room he would connect his non-B&O TVs with CAT5-PHONO for picture. The active IR-eye should be able to control the BeoCenter 2 even without a B&O TV being involved.
Has anyone else done something similar? Also as I can't get a Masterlink upto the 1st floor I think i'm going to have to go Wire-less - this should be ok if the signal is good?
Confused? so am I!
