1st March February 2012
Latest post 05-20-2009 3:01 AM by Dennis. 21 replies.
04-25-2008 8:04 AM
BeoSideOfLife
- Joined on 04-22-2008
- Posts 24
Is it still possible to upgrade the software in a BeoMaster 4500 to 2.1(or later) in order to get 2-way communication? Are the EEPROMs still in stock? If so, will it work with my precious MCP 6500 or did it only work with BL5000? Would make up a great weekend gift.
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
how can i confirm what software rev my bm4500 is running? i too would be interested in this... thx,
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
BeoSideOfLife:Crap! What differs between bl5000 and an mcp? Are there two versions of 2-way communication?
I am afraid there is!!! Otherwise an MCP would work properly with a BC9500 and it does not!!!!
burantek
- SE USA
- Posts 6,214
honestly, the bm is new to me. i got it about (2) months ago -still in the bubble wrap. so, i have not been able to chk the sticker on the back. i thought perhaps there may be some cmd's you could throw at it -that might display the current sw rev. the risk as i see it -is that it may have been flashed at some point, but the newer sticker may not have been placed. -i would sure like to know before investing in bl7000...
BeoSideOfLife
- Posts 24
Ok thats somewhat annoying. Could we perhaps put togeather a list of which 2-way remote works togeather with what unit? I for one would very much appreciate it. Btw, if the mcp was used just for BS6500 and 7000, how come that the BL7000 works with BS7000?
Ignace
- Joined on 03-30-2007
- Moderator - NL
- Posts 2,749
You could check if the 2-way is working by switching it on, adjust a setting, f.e. the volume and look (close-up) if the ir-emitters blink (very faint, may take a few seconds before they blink) The emitters are located in the glass panel, see image below.
My BM4500 only works in 2-way with Beolink 5000 & 7000, with the MCP 6500 there is no contact.
burantek
- SE USA
- Posts 6,214
looks like i am going to have to unpack it... lol i would love a bl7000, but they seem to demand huge $$$
joeyboygolf
- Posts 3,252
BeoSideOfLife: Ok thats somewhat annoying. Could we perhaps put togeather a list of which 2-way remote works togeather with what unit? I for one would very much appreciate it. Btw, if the mcp was used just for BS6500 and 7000, how come that the BL7000 works with BS7000?
There are two sets of control codes, MCP and Beolink. It's simple enough, the MCP only works 100% with BM stacking systems but some 5500 and all 6500/7000 are beolink compatible as well!
a2bur
- Joined on 04-20-2007
- Posts 262
Made two of my BM3500's two way with eprom part number 8341178 this give's you software 2.2 , it's the same part that's in the BM4500 . Easy to change and not expensive ( about £30 ) but don't know if they are still available . Richard
BeoSideOfLife
- Posts 24
@ Ignace Nice! To me there is nothing better than 4500. You wouldnt happen to have a broken cd4500 you are willing to sell for parts? Need to refurbish mine a litte. @ a2bur Did you get the parts from a dealer? Was this recently or should I excpect the worst?
a2bur
- Posts 262
Got the eprom from my dealer but was a few years ago , it was one of the few parts that was still available then , so would be even less now . If I remember correctly these eprom's can be copied if you have the equipment . Richard
camshaft
- Pennsylvania, USA
- Posts 575
I thought the 4500 software for 2-way communication was 2.0 and up, and that the 2.1 on the website was a typo. That would make more sense, as usually the first number (the 2) is used to indicate major changes, whereas the number to the right, after the decimal, is used to indicate minor revisions. Since 2-way communication is likely the biggest revision made in the 4500, I would expect that 2.0 would indicate it, not 2.1. Austin
-Austin (resident audiophile skeptic)
Ignace
- Moderator - NL
- Posts 2,749
BeoSideOfLife:@ Ignace Nice! To me there is nothing better than 4500. You wouldnt happen to have a broken cd4500 you are willing to sell for parts? Need to refurbish mine a litte.
A spare CD4500, no, but i do have some spare parts, what do you need ?
BeoSideOfLife
- Posts 24
I suppose one would never have a spare bg cd 4500.  I need the glass panel and if possible the chassi (could paint a 3500 aswell). I am currently having my dealer checking if grill and mirror panel is available otherwise i might be in need of that too.  If you have a grill for the beocord that would be awsome! Btw, does the chassi of the beogram differ from that of a beocord?
Dennis
- Joined on 02-01-2009
- Denmark
- Posts 172
Hi there
I have just replaced af piece in my Beomaster 3500, and now the display shows CODE. Does anyone know that code? I hope that you can help me. It would be great, if you that have replaced your SW still have the code.
Best Regards
Loudspeaker
I was borned with a Beolink 1000 in my hand!
Ever seen a Beomaster 6001? I have one! Look here.
Main system: Beovision AV9000, Beocenter 2300, Beosystem 3500, Beolab Penta MKIII, Beolab 3000, Beogram 6500, Beolink 1000, Beolink 5000, Beolink 7000
Wish list: Beolab 2,
Dennis
- Denmark
- Posts 172
Is there anyone that knows the code?
Ignace
- Moderator - NL
- Posts 2,749
I can't think of another code than the one Peter mentioned in the other topic :
- power off on Beomaster (disconnect from mains) - on Beolink 1000, press RADIO - plug in Beomaster 4500 (connect to mains) - press 1271 PLAY on Beolink 1000
Dennis
- Denmark
- Posts 172
Thanks, I'll try when I come home. Is there anyone that has the code for Beomaster 3500 if the code for Beomaster 4500 doesn't work?
Best Regards
Loudspeaker
Page 1 of 1 (22 items)
