Hi Mmaxx
Dead easy to connect BeoLab8000's to other equipment as long as what you want to connect to has a variable line level output.
In the cone section of the speaker (where you plug in the Powerlink cable) you will see a phono socket.  You can connect these to a piece of equipment with phono socket outputs OR you can purchase from a dealer a signal adaptor cable. This converts phono plug to twin speaker din plug.
Hope that helps.
Opman
