Hi i have recently noticed that the picture on my television is crooked/wonky.
By this i mean that instead of the top and bottom edges of the actual viewing image being parallel - the picture is higher/deeper at the left hand side of the TV and converges across the screen somewhat to the right, so the height of the pic LH side is nearly 5mm along the top edge and 3 mm along the bottom edge wider than the RH side of the actual viewing image!?!?!?
Hope that all makes sense?
Can anyone please shed any light on this problem and a cure for it if there is one?
Look forward to any help/repiles.
Fil
