Latest post 04-20-2008 10:07 AM by joeyboygolf. 5 replies.
Page 1 of 1 (6 items)
  • 04-19-2008 9:27 AM
    • Fil
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Posts 90
    Avant DVD 32 RF wonky picture!?
    Hi i have recently noticed that the picture on my television is crooked/wonky.
    By this i mean that instead of the top and bottom edges of the actual viewing image being parallel -  the picture is higher/deeper at the left hand side of the TV and converges across the screen somewhat to the right, so the height of the pic LH side is nearly 5mm along the top edge and 3 mm along the bottom edge wider than the RH side of the actual viewing image!?!?!?
    Hope that all makes sense?
    Can anyone please shed any light on this problem and a cure for it if there is one?
    Look forward to any help/repiles.
    Fil
  • 04-19-2008 11:06 AM In reply to
    Re: Avant DVD 32 RF wonky picture!?
    You can adjust this in the service menu via Earth Field Correction. Adjust Top Skew and Bottom Skew until the picture geometry looks correct.
    At least, that's how it works on my Avant MkIII
    Regards Graham
  • 04-19-2008 12:10 PM In reply to
    • Fil
    • Posts 90
    Crikey...sounds complicated...........have only  looked in the service menu once...frightened me to death!!
    Thanks for your quick reply
    Fil
  • 04-19-2008 12:42 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Fil, anything you decide to mess with in the service menu, I would recommend writing the values down first!
    At least you have something to return to if you goose everything up.
    Andy T.
    Poor me, never win owt!
  • 04-20-2008 9:34 AM In reply to
    • Fil
    • Posts 90
    Would it be better for me ( a techno dunce) to get a B&O engineer to do it?
    Regards
    Fil
  • 04-20-2008 10:07 AM In reply to
    I think so. Should not take him long so not very expensive.
    Regards Graham
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
