Latest post 04-16-2008 3:28 AM by joeyboygolf. 5 replies.
Page 1 of 1 (6 items)
  • 04-15-2008 11:16 AM
    Beosound 3000 + beoport
    Hi there
     A short while ago I posted an inquiry asking about setting up my bs3000 (small clamper) with beoport so i can play my computers music in my living room. I was advised that as mine is the small clamper version, it might or might not require a software upgrade to accept beoport - is there any way to tell if mine would require this? perhaps if i supplied the serial number?
     Also, if anyone knows what is involved in the software upgrade / costs etc? and is beoport wireless or does it use the masterlink socket?
     Many thanks, any advice appreciated
     Chopper
  • 04-15-2008 11:36 AM In reply to
    Re: Beosound 3000 + beoport
    I'm not sure I could give you the software version by the SN alone, but the software upgrades are generally not expensive. As for the BeoPort, that's the bigger impediment. At this point it is not wireless and requires an ML run from computer to main system. It is brilliant when this is possible, but it is an understandable pain in the ass when it doesn't.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 04-15-2008 11:46 AM In reply to
    Press N MUSIC or SHIFT A TAPE on your remote. If N MUSIC comes up on the BS3000 display then you have the software.
    Regards Graham
  • 04-15-2008 4:17 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Laughing Some times the simplest answer is staring you in the face!
    Poor me, never win owt!
  • 04-16-2008 3:25 AM In reply to
    I agree Andy.. We all often look for the complex answer, when a simple one exists. Graham came up with the simple answer.
    Regards Keith....
  • 04-16-2008 3:28 AM In reply to
    ErmMaybe I'm just a bit simple!!
    Regards Graham
