Its good to hear that the re-soldering of some of the joints on the power supply module appears to resolved the problem with not switching on.
Going back to the stand issue, if you look at the block diagram below, there are three modules involved with controlling and driving the stand motor. The microprocessor on PCB14 (Only P20 shown on the left) actually tells the "Motor Stand Control" what to do and we know this is working because you can move the stand manually with the left and right arrows.
The problem you have is going to be caused by either:-
- The "Motor Stand Feedback" module (PCB81) not producing the position feedback signal at pin 6 of P102 OR;
- The "Motor Stand Control" module (PCB80) not passing the position signal through to pin 2 of P180 OR;
- The microprocessor on module (PCB14) is not receiving and/or storing the position information which should arrive at pin 4 of P20 on PCB14
The signal which should be received back on pin 4 of P20 takes the form pulses for each degree of movement, if it receives no pulses, then it will store zero movement which is basically what you have. If you have access to an oscilloscope, then I would suggest you monitor pin 4 of P20 on PCB14 and manually move the stand to see what you get. If you do not have an oscilloscope, then the second best thing to do is monitor using a multimeter in the AC range and watch for voltage when you manually move the stand. This second method will not tell you that the pulses are correct, but it will show if a signal is being generated or not.
If the signal is not being generated at pin 4 of P20 then check at pin 6 on P102 on PCB81, if no signal here then the fault is going to be on Module 81.
If however, the signal on pin 4 of P20 on PCB14 appears to be good when moving the stand, then the fault is going to be on the AV and microprocessor module PCB14 and if this is the case we move into a much more complex area.
So, once you have been able to establish the status of the feedback signal, we should be able to determine the next step.
