Latest post 04-29-2008 2:39 PM by magnushj. 39 replies.
Page 2 of 2 (40 items) < Previous 1 2
  • 04-21-2008 4:11 AM In reply to
    • magnushj
    • Top 500 Contributor
    • Joined on 08-16-2007
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    Re: Avant stand problem
    I reheated some of the big solders on the power supply pcb, and that seemingly did the trick. Can't be sure just yet, but after pulling the cord and replacing it several times with the red led lighting up every time i feel confident that a dry joint was the culprit.
    The stand still doesn't park though. I tried programming 1 and 2 a couple of degrees to the left and to the right, but nothing happened when i tried them.
    Beocenter 9500+Beolab Penta mk2+Avant+MX7000+Beosound Ouverture+1xBeolab 6000 :)
  • 04-21-2008 8:00 AM In reply to
    • mhw
    • Joined on 06-29-2007
    • Norway
    • Posts 207
    • Gold Member
    Good to hear that you fixed the Avant! Smile
    But the Beocenter 9300 isn’t yours anymore Wink
  • 04-21-2008 8:07 AM In reply to
    Its good to hear that the re-soldering of some of the joints on the power supply module appears to resolved the problem with not switching on.
    Going back to the stand issue, if you look at the block diagram below, there are three modules involved with controlling and driving the stand motor. The microprocessor on PCB14 (Only P20 shown on the left) actually tells the "Motor Stand Control" what to do and we know this is working because you can move the stand manually with the left and right arrows.
    The problem you have is going to be caused by either:-
    1. The "Motor Stand Feedback" module (PCB81) not producing the position feedback signal at pin 6 of P102 OR;
    2. The "Motor Stand Control" module (PCB80) not passing the position signal through to pin 2 of P180 OR;
    3. The microprocessor on module (PCB14) is not receiving and/or storing the position information which should arrive at pin 4 of P20 on PCB14
    The signal which should be received back on pin 4 of P20 takes the form pulses for each degree of movement, if it receives no pulses, then it will store zero movement which is basically what you have. If you have access to an oscilloscope, then I would suggest you monitor pin 4 of P20 on PCB14 and manually move the stand to see what you get. If you do not have an oscilloscope, then the second best thing to do is monitor using a multimeter in the AC range and watch for voltage when you manually move the stand. This second method will not tell you that the pulses are correct, but it will show if a signal is being generated or not.
    If the signal is not being generated at pin 4 of P20 then check at pin 6 on P102 on PCB81, if no signal here then the fault is going to be on Module 81.
    If however, the signal on pin 4 of P20 on PCB14 appears to be good when moving the stand, then the fault is going to be on the AV and microprocessor module PCB14 and if this is the case we move into a much more complex area.
    So, once you have been able to establish the status of the feedback signal, we should be able to determine the next step.
    Regards Keith....
  • 04-22-2008 5:54 PM In reply to
    • magnushj
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    mhw:
     Haha, will update my signature.
  • 04-23-2008 2:38 AM In reply to
    Whats the status on the stand ?
    Regards Keith....
  • 04-23-2008 11:54 AM In reply to
    • magnushj
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    I'm working on it right now. I'm measuring changes in AC on pin 4 when I move the stand. I don't have an oscilloscope at home, so i have to make due with the trusty old multimeter.
  • 04-23-2008 2:51 PM In reply to
    • magnushj
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    I noticed something. If i turn the stand to one of the sides, then use the remote to turn it the other direction, it will not turn all the way in one operation. It stops some places, and I need to push the button again to make it turn further.
    Correction: If I keep holding the button, the stand will continue after about a second.
  • 04-24-2008 4:17 AM In reply to
    Given you don't have an oscilloscope and also the statement you made in your last post, I suggest you remove the wire from pin 2 on P180 on the Motor Control Motor and if the symptoms remain the same, then we can assume the position signal is not working.
    Regards Keith....
  • 04-25-2008 2:35 PM In reply to
    • magnushj
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    I've cut the position feedback wire, and now when i turn the tv on, the stand turns left for a while and then stops. If I turn the stand manually to one of the extreme positions and turn it back with the remote, it only stops once. Somewhere around half way. I guess this is timed, or my set must be haunted! Erm
  • 04-26-2008 2:35 AM In reply to
    I think it is timed by the microprocessor and based on what you have said and tested it seems that the microprocessor is not receiving pulses back with the movement, so when it times out, it stops.
    I think you are going to need to look at the position sensor first.
    Regards Keith....
  • 04-26-2008 4:23 PM In reply to
    • magnushj
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    I have a regulated power supply in the workshop on campus. I'll pull the stand-motor-box-thingy (Stick out tongue) from the TV, bring it there and hook it up to an oscilloscope. Do you know what the pulses should look like?
  • 04-29-2008 2:13 PM In reply to
    • magnushj
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    VICTORY!
    It turned out that the gear that was supposed to turn the variable resistor in the stand was broken, and did not turn the resistor when the stand turned.
    I applied some glue, and now it parks beautifully. Smile
  • 04-29-2008 2:16 PM In reply to
    Very well done, now you have a fully working AVANT
    Regards Keith....
  • 04-29-2008 2:18 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Party!!! HOORAY!!Party!!!
    Poor me, never win owt!
  • 04-29-2008 2:39 PM In reply to
    • magnushj
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    Yaaaaay! Thanks for all your help along the way, guys! Party!!!
