Thank you again Peter for the cue.
If you have, or can download the BeoSound 3200 Guide, that information is on page 19. To be helpful, I'll type it out below for you with the Beo 4 commands in capitals:
Naming 19
See the list of CD names
While any CD is playing press twice to see the names. MEMORY appears briefly, then the name of the current CD flashes. If it has no name, the disc number, e.g. DISC 1 appears
( NAME, NAME, MEMORY DISC 1 )
Press to list the names one by one
( Beo 4 arrows up or down are pressed )
I hope this is helpful. I have also never done this command, as we sit too far away from the BS 3200 display to be able to read it.
I would urge a little caution at this point as the next series of options listed immediately under the naming commands are titled Delete CD name . . .
One of the many virtues of Beoworld Gold membership is the ability to download the user manuals if you need or like to.
