It's funny how B&O defines priorities when they launch a "new" product. BeoSound 6 came out 7 years after BS2, and in 7 years B&O didn't learn that file transfers were faster with a USB 2.0 cable..especially when having 4Gb of music to transfer instead of the 2 Gb from BS2.
At least with BS2, you can take the SD card, put it in your PC card reader, and store music at real high speed. Using BS2 to store 1 album of 80 Mb takes 2 minutes, using the card reader with a 133x card takes 30 seconds..but you can't do that with BS6, because the flash memory is built-in! First B&O tell us that SD format is the future, then they release BS6 and Serenata, both using non-SD technology.
As for the sound, the original Samsung is rated at 92 dB S/N ratio, when BS6 has 87 dB. And frequency response goes from 20 hz-20KHz on the original Samsung to a strange 37 Hz on BS6..and B&O are not afraid of talking about superior sound performance & higher dynamic range compared to the competition..pure PR language, I'm afraid.
Instead of wasting so much time on the ugly leather case, they should have worked more on transfer speed & sound quality indeed..not to mention the OGG format compatibility, but no AAC compatibility, unlike the Serenata..who said all B&O products spoke the same language??
Reunion Island is greeting you!
