I am wondering what would be involved in gettting a Beosound 9000 MK1 Nmusic compatible. Under the FAQ's on this site there are two conflicting solutions for this issue.
Beosound 9000 Nmusic upgrade
One FAQ on this site says:
Please note that the upgrade of the BeoSound 9000 MK1 model is very extensive, while the others simply involve replacing a chip
However another says:
BeoSound 9000 type 252x produced from April '96 (MkI) and Beosound 9000 type
256x (MkII) produced from September '98 simply require a software update. It is a
chip change, and although the software level may change from time to time the
part number remains the same - which is 8344087. Quote this to your dealer if
they are unsure.
So which is it? Just a simple software/chip change on a MK1 or do other parts need to be replaced?
