Latest post 04-03-2008 3:11 PM by Keith Saunders. 4 replies.
Page 1 of 1 (5 items)
  • 04-03-2008 6:02 AM
    Beosound 9000 NMusic upgrade
    I am wondering what would be involved in gettting a Beosound 9000 MK1 Nmusic compatible. Under the FAQ's on this site there are two conflicting solutions for this issue.
    Beosound 9000 Nmusic upgrade
    One FAQ on this site says:
    Please note that the upgrade of the BeoSound 9000 MK1 model is very extensive, while the others simply involve replacing a chip
    However another says:
    BeoSound 9000 type 252x produced from April '96 (MkI) and Beosound 9000 type
    256x (MkII) produced from September '98 simply require a software update. It is a
    chip change, and although the software level may change from time to time the
    part number remains the same - which is 8344087. Quote this to your dealer if
    they are unsure.
    So which is it? Just a simple software/chip change on a MK1 or do other parts need to be replaced?
  • 04-03-2008 8:08 AM In reply to
    Re: Beosound 9000 NMusic upgrade
    As far as I am aware the kit to update the Mark I & II is the same and certainly has the same part number.
    To update previous BeoSound 9000s, Type 252x and 256X, with software version 2.5 order part no. 8344087
    Regards Keith....
  • 04-03-2008 8:17 AM In reply to
    I can confirm that it is just a software change. Part number is 8344087 as Keith says.
    I have done several, probably into double figures and have had no problems.
    Regards Graham
  • 04-03-2008 10:44 AM In reply to
    Hi Graham and Keith....I've got a MK I.....it's in south america...ie. no BnO service....
    Once I buy the software upgrade....how do I install it???
    Thanks,
    Keith
  • 04-03-2008 3:11 PM In reply to
    Keith,
    If you buy the chip upgrade you will need a plastic removal tool and an anti-static wrist strap.
    In the picture below you will see the location of the chip to be replaced.
    Regards Keith....
