Latest post 04-03-2008 2:18 PM by joeyboygolf. 13 replies.
Page 1 of 1 (14 items)
  • 04-03-2008 3:22 AM
    Please help with moving Question: Will my stereo work elsewhere?
    I know many of you don't live in Italy but I figured I would ask the question before I talk to my B&O dealer. I have a Beosound 9000 and I am moving to Italy for a couple years from the United States. Will the stereo work in Italy and if not, what will I need to make sure it works?
    I don't want to bring it all the way to Italy if I can't use it. Any help is appreciated.
  • 04-03-2008 3:56 AM In reply to
    Re: Please help with moving Question: Will my stereo work elsewhere?
    European electrical systems are 220v so your US spec equipment will need a step down transformer to enable it to function in Italy.
    Regards Graham
  • 04-03-2008 4:04 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    I don´t think the radio will work. Different frequencies.
  • 04-03-2008 7:22 AM In reply to
    I heard the story about the radio too when I moved with my BS2300 from Germany to US. In the end it worked even RDS.
     It is correct though that frequencies are a bit different.
  • 04-03-2008 7:38 AM In reply to
    I Remember you speakers  sent you a PM - however the above has said the same!! Remember the speakers if US will need the same in most cases and these use a lot more power!
  • 04-03-2008 8:10 AM In reply to
    The radio will work in Italy just fine. Slightly different FM range but not sufficient to cause major problems.
    Regards Graham
  • 04-03-2008 10:51 AM In reply to
    joeyboygolf:
    What about the frequency stepping? In the past I had a US car radio and the frequency steps were fixed to x,0 x,2 x,4 x,6 .... so it was not possible to tune the local station at 95,5MHz (in Germany).
    Marcus
  • 04-03-2008 11:39 AM In reply to
    Quoted Before: European electrical systems are 220v so your US spec equipment will need a step down transformer to enable it to function in Italy.
    What is a step down transformer? Approximately how much does htis cost?
  • 04-03-2008 11:48 AM In reply to
    For some reason, I thought that the step up converter is in the American cord. I thought you only needed the European cord. Is this correct?
  • 04-03-2008 12:54 PM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    iphone:
    I don´t know about the rest of the old world but Sweden has changed to 230/400 V. It´s 15 years ago but people still say 220/380! Angry
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    Sorry, double post!
  • 04-03-2008 1:02 PM In reply to
    Issue has been resolved. B&O recommended a voltage converter from 110 to 220 at the airport or electronics store (they did not sell them).
    If the sound is poor, they may need to do an internal conversion but that is probably not required. Thanks everyone.
  • 04-03-2008 2:15 PM In reply to
    marcus_m:
    joeyboygolf:
    Marcus
    The only difference between US and EU spec is the FM range covered. I have done this conversion and the radio works fine.
    Regards Graham
  • 04-03-2008 2:18 PM In reply to
    Daniel:
    iphone:
    Europe has standardised on 230v + or -. Could drop as low as 220 or be as high as 240 but this makes no difference to the equipment.
    Regards Graham
