Latest post 04-03-2008 8:52 AM by camshaft. 5 replies.
Page 1 of 1 (6 items)
  • 04-01-2008 6:03 PM
    • demonell
    • Not Ranked
    • Joined on 03-31-2008
    • Cheltenham
    • Posts 44
    USA equipment in the UK
    Can anyone enlighten me. Is there any reason why a 120v USA beosound 3200 would not work in the UK with an appropriate voltage converter?
    Thank you.
    Dan
  • 04-01-2008 6:36 PM In reply to
    Re: USA equipment in the UK
    With all the other models in the range there is no need for a voltage converter. You can just move a couple of jumpers on the power supply and it will work no probs. Should take no more than 1 hour.
    I'm not sure about the 3200 as it's innards are different and I have not had one apart. The service manual is not very helpful.
    Regards Graham
  • 04-01-2008 6:57 PM In reply to
    • demonell
    • Not Ranked
    • Cheltenham
    • Posts 44
    Thanks Graham, most helpfull.
    Dan
  • 04-03-2008 6:00 AM In reply to
    Graham, do you know if this applies to the BeoSound 9000? I'm thinking of buying one from the US for a friend, to use in Australia.
    Cheers
    Stuart
  • 04-03-2008 8:42 AM In reply to
    I'm sorry to say that it does not apply to BS9000's.
    The 120v version is different and it is financially not viable to convert them to 240v. I have done one in the past but I bought it very cheap and considered it worthwhile.
    You could consider using an external transformer.
    Regards Graham
  • 04-03-2008 8:52 AM In reply to
    • camshaft
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Pennsylvania, USA
    • Posts 575
    Just to add to the info here, older beogram turntables (I'm not sure about the more recent ones) won't work across countries with only a voltage transformer or internal voltage change because the motor speeds are based on the frequency of the power current.  This means the motor has to be changed or modified.
    -Austin (resident audiophile skeptic)
