Latest post 04-06-2008 4:02 PM by marrow999. 4 replies.
Page 1 of 1 (5 items)
  • 03-31-2008 6:59 PM
    Plasma picture adjustments BV4 - factory reset?
    A little knowledge is clearly a dangerous thing - having gone into the service menu and attacked the TV monitor - picture adjustments with gusto,  I now seem a mile off! Can I calibrate the monitor with a spider - I believe this is a built in feature on the newer screens?
    Anyway - first stop is to reset all - is that possible?
     Many thanks
    Mark
  • 03-31-2008 10:18 PM In reply to
    • Beolab
    • Top 150 Contributor
    • Joined on 05-18-2007
    • Sweden
    • Posts 535
    Re: Plasma picture adjustments BV4 - factory reset?
    marrow999:
     Many thanks
    Mark
    Have you tested the  "Reset to default option" in the service menu?
    Regards
    BL8000 MkII Black
  • 04-05-2008 11:48 AM In reply to
    In the service menu for the monitor I have 13 categories, but none of these seem to include a reset to default
    I'm in menu - set up - 00 go - monitor....
    Should I be looking elsewhere?
     Many thanks
    Mark
  • 04-05-2008 4:03 PM In reply to
    • 355f
    • Top 100 Contributor
    • Joined on 04-19-2007
    • Posts 655
    marrow999:
     Many thanks
    Mark
    Have you got BS2 with it??  you will need the panasonic remote and fire it at the back of the BV4. The spider is not that good a calibration tool-
  • 04-06-2008 4:02 PM In reply to
    I havent got the panasonic remote - yes its with the BS2? Does that give me other options?
    Many thanks
    Mark
