A little knowledge is clearly a dangerous thing - having gone into the service menu and attacked the TV monitor - picture adjustments with gusto, I now seem a mile off! Can I calibrate the monitor with a spider - I believe this is a built in feature on the newer screens?
Anyway - first stop is to reset all - is that possible?
Many thanks
Mark
marrow999:A little knowledge is clearly a dangerous thing - having gone into the service menu and attacked the TV monitor - picture adjustments with gusto, I now seem a mile off! Can I calibrate the monitor with a spider - I believe this is a built in feature on the newer screens?Anyway - first stop is to reset all - is that possible? Many thanks Mark
Have you tested the "Reset to default option" in the service menu?
Regards
BL8000 MkII Black
In the service menu for the monitor I have 13 categories, but none of these seem to include a reset to default
I'm in menu - set up - 00 go - monitor....
Should I be looking elsewhere?
marrow999: In the service menu for the monitor I have 13 categories, but none of these seem to include a reset to defaultI'm in menu - set up - 00 go - monitor....Should I be looking elsewhere? Many thanks Mark Have you got BS2 with it?? you will need the panasonic remote and fire it at the back of the BV4. The spider is not that good a calibration tool-
I havent got the panasonic remote - yes its with the BS2? Does that give me other options?
