Dear Graham
Thank you for the prompt reply. I am not sure how to carry out the necessary connections between the metal shield of the din from the deck and the chassis of the amp. I have physically touched the shield area to the chassis but that has not stopped the hum. However, if I disconnect the the Din from the adapter, but place my thumbs over the end of each making me the earth the hum continues. but if I do the same at the same time as touching the lead to my headphones -when plugged in_ the hum stops. I am sorry but I have not real technical knowledge, so if you could explain a bit more on how I should do this  I would be very grateful.
Sound-smiths, from whom I got my cartridge, said they thought there should be a earth wire or post on the body of the turntable, but I cannot find one. Was I right in thinking that it was the connection with the beomaster the previously supplied the earth?
Thanks again for your help, I can see that there should be a way of solving this problem.
Regards
Keith
