Latest post 05-10-2007 6:41 PM by EOB. 7 replies.
Page 1 of 1 (8 items)
  • 05-03-2007 5:58 PM
    • EOB
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Posts 188
    motorstand MX5500
    Somehow it seems that the stand falls into a standstill .....if i push it a little it will continue.....is this due to wear inside the motor and can it be helped. Or might it be of influance that I mounted a MX3500 on it ?  ( maybe not quite in balance as the MX5500 ?)...
  • 05-04-2007 8:24 AM In reply to
    Re: motorstand MX5500
    Unlikely to be due to weight/balance ... try wiggling the stand wire ...
  • 05-04-2007 10:59 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    nobby:
    Is that the technical term for it then mate.Laughing
    CraigBig Smile
  • 05-04-2007 11:37 AM In reply to
    • Kevin
    • Top 50 Contributor
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    That's experience that is...... won't learn that at collegeWink
  • 05-04-2007 11:57 AM In reply to
    • EOB
    • Posts 188
    Tried the wigle part ;)......I took the plug out and i am not sure ....is the green wire suposed to be not conected to a pin ? only 3 wires are conected.......
  • 05-04-2007 2:59 PM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    I think all four wires need to be connected for the motor stand to work. It might solve the problem, can anyone confirm??
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 05-08-2007 11:13 AM In reply to
    • EOB
    • Posts 188
    took the din a bit further apart:
    4 pins 3 are conected 1 seems to be never coneted.
    but maybe this might be the cause ; th outer shield of the din has barely to no contact with shield around the cable.........isn`t it suposed to be the earth shield so conected to the din metal outer part ?
  • 05-10-2007 6:41 PM In reply to
    • EOB
    • Posts 188
    for referene purposes;
     I have put the fastening inside the din which might be touching the outershield of the cable wire a bit further so it was unlikely that it would touh.....
     the other 3 conections in the din are now a little cramped but hey when tried ,.....it works !
     Of course i would like to know if it is due to the shield part or maybe a wire breah that somehow now is fixed ,....but in the end ...it can be used Cool
    Thx for replies and help
