Hi Austin - i take your point but the rings supplied to me are compared to the original penta units below
Outer diam penta 77.5 goodhifi 77.0
outer(inner) diam penta 74.5 good hifi 67.5
inner(outer) diam penta 58.0 good hifi 55.5
inner(inner) diam penta 52.0 good hifi 46.0
the good hif rings have a flat aspect the penta has an angled one - I am worried the extra 3mm encroachment onto the cone will affect performance as will any stress/strain imposed by the flat ring being mounted at an angle - anyone out there with observations, comments etc.
There is another Ebay supplier, Germany/Austria based, more expensive, but the rings are similar to the penta dimensions however I am currently trying to ascertain whether flat or angled - these are suggested for repair of Grundig units.
http://cgi.ebay.de/2-99-Sicken-foam-surrounds-sondermass-High-Quality-F88_W0QQitemZ180213512110QQihZ008QQcategoryZ141261QQcmdZViewItemQQ_trksidZp1742.m153.l1262
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=110131651907&ssPageName=ADME:X:AAQ:DE:1123
As previously comments/advice would be most useful!
tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
