marcus_m: Have you tried changing the option programming to 1?
Marcus
Marcus wins.
With the Beo4, I change the BeoVision1 OPTION to 1.
The Beo1 now works in all its glory.
However the Beo4 no longer works, which is a shame because I was hoping to be able to use both. I need to be able to press SAT/DVD/RADIO to access the linked sources.
So OPTION1 worked, where can I find more info on the different options? I have put the BV1 back to OPTION 6 for the Beo4 to work again for now.
What I really would like is, both Beo1 & Beo4 work at the same time.
I love this site, I knew someone would have the answer eventually.
