Latest post 03-29-2008 6:55 AM by gorissek. 15 replies.
Page 1 of 1 (16 items)
  • 03-27-2008 8:59 AM
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    BEO1 Help required
    Thanks to LifeStyle-AV I have a new Beo1 remote control.
    However none of the buttons work with my BeoVision 1LS or Avant except, if I hold down the power button then everything goes into standby.
    In the BeoVision 1 service menu "Remote Control" is set to Beo1 with SW? although I have been using a Beo4 in the past.
    Do I have to do something to make it work?
  • 03-27-2008 12:59 PM In reply to
    • UK
    • Posts 970
    Re: Tech help req:- Beovision 1 LS & Beo1
    What is the Beo1 compatible with?
  • 03-27-2008 1:51 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    britops:
    Beovision 1 & Beocenter 1 acording to the products section.
    BEO1 link
    CraigSmile
  • 03-27-2008 2:28 PM In reply to
    • UK
    • Posts 970
    britops:
    So is my Beo1 a dud?
  • 03-28-2008 3:46 AM In reply to
    • UK
    • Posts 970
    I unplugged the masterlink from the Bv1 but still the remote did nothing.
    Does anyone know about the Service Menu "Remote Control" section and why mine has ???? all over it.
  • 03-28-2008 2:22 PM In reply to
    • UK
    • Posts 970
    Its very quiet around here. Your all loosing your touch, does no-one have any idea's for me?
  • 03-28-2008 2:51 PM In reply to
    • Craig
    • Posts 4,855
    Is the remote sending out a beam for anything other than stand by. You may be able to see the LED in the end lighting up with the naked eye. If not try looking at it with the camera on a mobile phone.
    CraigSmile
  • 03-28-2008 3:31 PM In reply to
    Have you tried changing the option programming to 1?
    Marcus
  • 03-28-2008 4:49 PM In reply to
    Richard,
    Sorry for the delay in responding to your question.
    The Beo1 was sold with some versions of the Beocentre 1 and Beovision 1
    Your Beovision LS Type 865X was sold with a Beo4.
    You can look at the "Remote Control" type in the Service Menu by:-
    • Press MENU to get yourself into the Beovision MENU
    • Press 0 0 GO which then takes you to the Service menu
    You should see 4 items in the list namely:-
    • Monitor Information
    • TV-Tuner
    • Stand
    • Remote Control
    Move the cursor down to "Remote Control" and it will almost certainly say Beo4
    Regards Keith....
  • 03-28-2008 5:27 PM In reply to
    • Craig
    • Posts 4,855
    Keith Saunders:
    Richard,
    • TV-Tuner
    • Stand
    • Remote Control
    So does this mean a Beo1 will not control all Beocoenter/Beovision 1's?
    CraigSmile
  • 03-28-2008 5:47 PM In reply to
    • UK
    • Posts 970
    Keith Saunders:
    Richard,
    • TV-Tuner
    • Stand
    • Remote Control
    Thanks Keith, it says Beo1.
  • 03-28-2008 5:49 PM In reply to
    • UK
    • Posts 970
    Craig:
    CraigSmile
    I see 2 lights for every button pressed. Thanks I like that trick, I wasn't sure what to expect when I read your post.
  • 03-28-2008 6:17 PM In reply to
    • UK
    • Posts 970
    marcus_m:
    Marcus
    I will try, once I re-read my manual how to.
  • 03-29-2008 3:52 AM In reply to
    I think you are rapidly discovering that the Beo1's primary use is that of a paperweight! I can't understand why it isn't working as you seem to have done everything sensible!
  • 03-29-2008 6:26 AM In reply to
    • UK
    • Posts 970
    marcus_m:
    Marcus
    Marcus wins. Party!!!
    With the Beo4, I change the BeoVision1 OPTION to 1.
    The Beo1 now works in all its glory. Big Smile
    However the Beo4 no longer works, which is a shame because I was hoping to be able to use both. I need to be able to press SAT/DVD/RADIO to access the linked sources.
    So OPTION1 worked, where can I find more info on the different options? I have put the BV1 back to OPTION 6 for the Beo4 to work again for now.
    What I really would like is, both Beo1 & Beo4 work at the same time.
    I love this site, I knew someone would have the answer eventually.
  • 03-29-2008 6:55 AM In reply to
    A bit off topic, but I really want to know why did they decide that Beo1 will only work with BV1/BC1? I understand you need a screen for the menus, but still, I think it would be perfect for simple commands ( like volume, next song, stop, play,... ) on a music system.
    Anyone with any info on that one?
