Hi
I want to get a new DIN to phono lead made for my Beogram 4000 to go with some interconnects for the rest of my system - quick question - how are the pins in the DIN plug wired up?
Cheers
Pin 3 = Left
Pin 5 = Right
Pin 2 = Ground
Remember that you also need an earth from the casing of the DIN plug as this grounds the chassis. Without it you will get hum.
Thank you Sir!
I presume that the Ground pin is different to the earth from the DIN plug casing? Which is the one that actually goes into the amp alongside the phono plugs?
