Latest post 06-03-2008 3:31 PM by agenten007. 9 replies.
Page 1 of 1 (10 items)
  • 03-17-2008 8:48 AM
    • KimP
    • Not Ranked
    • Joined on 03-17-2008
    • Posts 5
    New intelligent lightdimmer for B&O remotes
    The RAone SmartDimmer is perfect for creating a specific mood anywhere in your home. This Danish designed and developed light dimmer is operated by a light touch of the finger-touch panel. With the INNOVUS SmoothRemote, a B&O remote or a Logitech Harmony 890PRO or Harmony895, you can operate the light dimmer from your sofa or from bed.
    The RAone SmartDimmer is more than a light dimmer. It is your entrance ticket to a world of opportunities for smart-controlling your home. The RAone SmartDimmer was created as a part of the INNOVUS Home Automation system, by which lighting, heating and security are controlled via central switches or a remote control device, providing convenience, security and energy savings.
    The RAone SmartDimmer in the children's room
    The RAone SmartDimmer helps your children fall asleep. Two light touches of the light dimmer and the light will fade slowly over a half hour while the children fall asleep.
    The RAone SmartDimmer as energy meter
    The RAone SmartDimmer has a built-in electricity meter that measures the electricity consumption of the lamp to which it is attached. Together with INNOVUS House Control, it provides a valuable overview of the energy consumption in your home. (The electricity measuring function requires INNOVUS House Control.)
    http://shop.innovus.dk/group.asp?group=8
  • 03-17-2008 12:22 PM In reply to
    Re: New intelligent lightdimmer for B&O remotes
    http://forum.beoworld.org/forums/thread/97358.aspx Wink
  • 03-17-2008 12:59 PM In reply to
    • NESLO
    • Not Ranked
    • Joined on 12-28-2007
    • Posts 28
    Et godt produkt som kan anbefales er fra firmaet "unotec"
    http://www.unotech.dk/cms/images/stories/Loesningspdf/B-O.pdf
  • 04-15-2008 2:18 AM In reply to
    • Hank
    • Not Ranked
    • Joined on 04-17-2007
    • Posts 25
    Någon som vet om RAone SmartDimmer  fungerar tillsammans med Plasma TV, vilket LC2an inte gör.
    Best Regards Hank
  • 04-15-2008 2:34 AM In reply to
    Hank:
    Ang RAone vet jag inte, men att LC2 funkar med plasma. Äldre LC2 kan man modifiera. Har gjort det med 3 st utan kostnad
  • 04-15-2008 6:22 AM In reply to
    Jeg har to RAOne enheter og en LC2 i samme værelse med en Pioneer 50" Kuro. Ingen problemer.
  • 04-25-2008 3:24 AM In reply to
    Yesterday I discovered that when the screen is very bright, almost all white, then the dimmers don't work. Clearly the plasma was interfering. I had a bright image up, and lost control of the RAone's. But when the image changed to a regular contrast one, then there was no problem.
  • 05-11-2008 6:12 PM In reply to
    mr_anders_son:
    Hank:
    Tjena Anders!
    Vet du vad man gör vid en uppgradering?
    Lödar de om IR-mottagarna?
    /Ola
  • 06-02-2008 1:30 PM In reply to
    Hej.
    Nogen her der ved om LK`s wireless ihc system kommer til at kunne betjenes med B&o fjernbetjening.
  • 06-03-2008 3:31 PM In reply to
