The RAone SmartDimmer is perfect for creating a specific mood anywhere in your home. This Danish designed and developed light dimmer is operated by a light touch of the finger-touch panel. With the INNOVUS SmoothRemote, a B&O remote or a Logitech Harmony 890PRO or Harmony895, you can operate the light dimmer from your sofa or from bed.
The RAone SmartDimmer is more than a light dimmer. It is your entrance ticket to a world of opportunities for smart-controlling your home. The RAone SmartDimmer was created as a part of the INNOVUS Home Automation system, by which lighting, heating and security are controlled via central switches or a remote control device, providing convenience, security and energy savings.
The RAone SmartDimmer in the children's room
The RAone SmartDimmer helps your children fall asleep. Two light touches of the light dimmer and the light will fade slowly over a half hour while the children fall asleep.
The RAone SmartDimmer as energy meter
The RAone SmartDimmer has a built-in electricity meter that measures the electricity consumption of the lamp to which it is attached. Together with INNOVUS House Control, it provides a valuable overview of the energy consumption in your home. (The electricity measuring function requires INNOVUS House Control.)
http://shop.innovus.dk/group.asp?group=8
