1st March February 2012
Latest post 08-02-2009 5:14 AM by tournedos. 71 replies.
03-16-2008 7:18 AM
Bulgarien
- Joined on 04-17-2007
- Denmark, Vest Sjaeland
- Posts 201
New intelligent lightdimmer for B&O remotes
The RAone SmartDimmer is perfect for creating a specific mood anywhere in your home. This Danish designed and developed light dimmer is operated by a light touch of the finger-touch panel. With the INNOVUS SmoothRemote, a B&O remote or a Logitech Harmony 890PRO or Harmony895, you can operate the light dimmer from your sofa or from bed.
The RAone SmartDimmer is more than a light dimmer. It is your entrance ticket to a world of opportunities for smart-controlling your home. The RAone SmartDimmer was created as a part of the INNOVUS Home Automation system, by which lighting, heating and security are controlled via central switches or a remote control device, providing convenience, security and energy savings.
The RAone SmartDimmer in the children's room The RAone SmartDimmer helps your children fall asleep. Two light touches of the light dimmer and the light will fade slowly over a half hour while the children fall asleep.
The RAone SmartDimmer as energy meter The RAone SmartDimmer has a built-in electricity meter that measures the electricity consumption of the lamp to which it is attached. Together with INNOVUS House Control, it provides a valuable overview of the energy consumption in your home. (The electricity measuring function requires INNOVUS House Control.) http://shop.innovus.dk/group.asp?group=8
Coolskin
- Joined on 04-16-2007
- Holland
- Posts 505
Re: New intelligent lightdimmer for B&O remotes
Bulgarien:
If this product has the same (or better) IR-"reach" as the LC2 i'm interested in the bundle of 3. Too bad the order info isn't in GB yet...
Bulgarien
- Posts 201
It should be the same.. Notice that is the remote and not the IR reciever that make the difference in reciving the signal . Beo4 are much "stronger" compared to others remotes. It´s possible to ordre in english (just push on the GB flag at the top at the screen.
jk1002
- Boston USA
- Posts 1,620
Does this work in the US and will you ship there? Also, can it be programmed and how so I can have multiple in the same room.
Karel Uyttendaele
- Joined on 05-19-2007
- Aalst, Belgium
- Posts 682
Have been using this dimmer for some time.. works perfectly! Superb IR reception!!!! The Dynalight dimmers are crap compared to this dimmer!
The race for quality has no finish line- so technically, it's more like a death march.
Bingo
- Posts 922
Karel, can you also switch lights off or only dimm with it? I have several Megaman Dors 4 steps dimming lamps at home and it only works when you really can turn the electricity off to the lamp at once.
Karel Uyttendaele
- Aalst, Belgium
- Posts 682
Bingo: Karel, can you also switch lights off or only dimm with it? I have several Megaman Dors 4 steps dimming lamps at home and it only works when you really can turn the electricity off to the lamp at once.
They act just as a LC2! On/off - dimming
mr_anders_son
- Joined on 03-27-2007
- sweden
- Posts 1,032
sounds very interesting can you use it for electronic transformer to?
DaveL
- Cambridgeshire, UK
- Posts 11
I have looked at the user guide and makes mention of low energy bulbs, but can it be programmed like the LC2 for specific use for this so it only works in the on/off mode? I could see no reference to this in the operation section of the guide. DaveL
PhilLondon
- London
- Posts 2,545
Can they be programmed like LC2, with 10 different light moods? (LIGHT+1, etc...)? Where did you guys find the user guide? p.
Karel Uyttendaele
- Aalst, Belgium
- Posts 682
To summerize: everything the LC2 can do this dimmer can do to. Manual at: http://www.innovus.eu/fileadmin/user_upload/manual/UK/RAone_SmartDimmer.pdf Additional feature: it has an auto dimmer which dimms the light from the current intensity to off in a period of 30min when you touch the alu front twice breefly.
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Xseries:
Seems very cheap compared to the price of LC2's before they ended production. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Bulgarien
- Posts 201
Notice that the next version of the RAone lightdimmer that comes in this month (marts/april) will could be used with the new ligtning tecnology called LED or OLED. LED lamps will only be possible to dimmer with new generation of lightdimmers. A LED lamp that gives the same light as a normal 40 Watt bulb, are only using 5-7 watt and normal (old) lightdimmers will not could be used, becouse the ampere (A) is to low http://www.rgb-lamps.dk/FarveL12.htm Today its only possible to get 40 Watt LED with a life time of 50.000 hours . Proberly next year it will be possible to get a 60 Watt LED with same lifetime, and then it vill be time for change bulbs in the hole house.
B&Ola
- Posts 302
Just bought the 3-pack. =) Looking forward to see if they are as good as the LC2 regarding IR-reception. Is it possible to activate the 30-min dim by the remote? /Ola
turbotol
- Posts 46
So from the specs it seems there is no US product yet? Any idea when the US version will be available and at what price?
Ehlerz
- DK
- Posts 510
FYI i got my 3 dimmers today, and unfortunately i cant seem to get any of them to work. One does not work at all, the other two turns on the lamp at about 50 % but does not react to touch or anything. Can anyone help with this issue? As i am aware, they should work right out of the box and that is also what is mentioned in the userguide. Does anyone have them up and running?
BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
mfirst
- Joined on 04-21-2007
- Posts 155
US version?
please?
-michael
B&Ola
- Posts 302
Ehlerz: FYI i got my 3 dimmers today, and unfortunately i cant seem to get any of them to work. One does not work at all, the other two turns on the lamp at about 50 % but does not react to touch or anything. Can anyone help with this issue? As i am aware, they should work right out of the box and that is also what is mentioned in the userguide. Does anyone have them up and running?
This doesn't sound good. I havn't got mine yet. Hope they will work. Ehlerz, where are you located? When did you order yours? /Ola
Bobby2000
- Joined on 03-31-2008
- Posts 1
I have 3 RAone dimmer installed and are using them with my BEO4 remote. It is important that the neutral and the live wires on the input terminals are connected properly. Otherwise the touch plate will not work. If anyone has problems with this please try to reverse the input wires or the AC plug. A new version of the H/W should come out in Marts. The new version has some improvements on this issue.
Robert
- Joined on 06-13-2007
- Northern Ireland
- Posts 362
I would be interested in some of these, but may wait for the updated version. Does it just work with a dimming lamp, or could it work with just a standard on/off lamp? What actual control with Beo4/5 do you get? Robert.
Ehlerz
- DK
- Posts 510
B&Ola: Ehlerz: FYI i got my 3 dimmers today, and unfortunately i cant seem to get any of them to work. One does not work at all, the other two turns on the lamp at about 50 % but does not react to touch or anything. Can anyone help with this issue? As i am aware, they should work right out of the box and that is also what is mentioned in the userguide. Does anyone have them up and running?
Hi Ola I ordered mine approximately 10 days ago i think and am located in Denmark. I will have another go with the dimmers tomorrow evening and a friend will see if he can help me out. I will keep you posted!
Bulgarien
- Posts 201
I ordered also a set of RAone Vers. 2.0 today . They will come in April . I like the (B&O) design with real steel and the small green LEDs as display very much, the brand new technology and specially the price. I have tryed JO-el Dina light dimmer, but they was in a very cheap quality, and have not the B&O feeling, that we like. I think that RAone will be great lightdimmer for use with our B&O equipment. This year, or next years, when we can get all the new kind of low energy LED/OLED bulbs, then will LC2 been outdated. No one will use old bulb anymore. I mean to know, that in United Kingdom and Australia they are already forbidden I don’t think that B&O will delivery a new LC3 light dimmers with this kind of technology, and if they can, it will properly be to expensive for me... :-( But at the first time, I´m prepared to the future ;-)
