Latest post 08-02-2009 5:14 AM by tournedos. 71 replies.
Page 2 of 3 (72 items) < Previous 1 2 3 Next >
  • 04-06-2008 5:05 PM In reply to
    Re: New intelligent lightdimmer for B&O remotes
    I've got mine now. They work great! Im really satisfied.
    Its really great because the work with radio waves also. (like NEXA...)
    8 x LC2 for sale! (or maybe I wait a month or two to se if they still work)  =)
    /Ola
  • 04-07-2008 1:35 AM In reply to
    B&Ola:
    /Ola
    Do you know if it can handle Nexa remotes?
  • 04-07-2008 5:06 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Hi Ola,
    what about IR reception. Is it as good as with LC2s? Do you also use House Control?
    Thanks Stefan
  • 04-07-2008 7:57 AM In reply to
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    Can you program them with a BEO5 (manual only mentions BEO4) ?
    Do they deliver across Europe?
  • 04-07-2008 10:30 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Doc:
    You can use the Beo5 and program them with it. No poblems. I got mine after 14 days to make the order and I am in Spain. They send them by denmark Post.
    Regards
    Quim
  • 04-07-2008 1:24 PM In reply to
    • Doc
    • Posts 585
    Quim,
    Did you receive the latest version (with which LED can be controlled) ?
  • 04-07-2008 4:18 PM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Doc:
    Quim,
    I don't think so, but i don't know for sure. I use them with normal lamps. Sorry.
    Quim
  • 04-07-2008 4:45 PM In reply to
    ....mr anders(son):
    B&Ola:
    /Ola
    No, sorry. It works with Z-wave and not with Nexa which uses a different frequency than Nexa and equivalent.
    /Ola
  • 04-07-2008 4:51 PM In reply to
    stefan:
    Hi Ola,
    Thanks Stefan
     Hi
    No, the reception is not as good as LC2 but good enough. (It's not as bad as the Dynalight.)
    /Ola
  • 04-08-2008 1:15 PM In reply to
    Hi Ola
    Do you know if it the dimmers "speak" together using zwave. Say i have one dimmer in my livingroom and one in my bedroom. Is it possible to turn on the light in the bedroom from the livingroom aiming your remote at the dimmer installed in your livingroom and then letting it transfer commands (zwave) to the bedroom? Could be possible as you can name the dimmers from 1 to 9.
    That would IMO be so very cool.
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 04-09-2008 10:23 AM In reply to
    • Hank
    • Not Ranked
    • Posts 25
    Is it plasma protected?
    I have LC2 now and I can´t use it when my plasma sceen is on, I hope I can use this dimmer togheter witth my plasma.
    Any one who knows?
    Best Regards Hank
  • 04-09-2008 3:44 PM In reply to
    Ehlerz:
    Hi Ola
    Sorry to say but I don't think it's possible but can't say for sure.
    /Ola
    Ehlerz:
    Hi Ola
    /Ola
  • 04-14-2008 1:48 AM In reply to
    • Hank
    • Not Ranked
    • Posts 25
    Anyone with experience from this dimmer and plasma screen, does it work toghter with a plasma TV?
    Best Regards Hank
  • 06-09-2008 6:25 AM In reply to
    Can they be wall mounted, to use in place of a wall switch?
     p.
  • 06-09-2008 10:11 AM In reply to
    Answering myself...
    The web site mentions Wall mounted or Floor mounted..
     Anyway... I have just ordered a pack of 3 and will order more if I am happy.
    p.
  • 12-16-2008 9:01 AM In reply to
    A new and even nicer dimmer is now available:
    http://www.lintronic.dk/AluDim.htm
    The spec's are also very good - it can dim all loads, and it also includes "light scenes".
  • 12-16-2008 2:04 PM In reply to
    Do anybody have pictures of installed  Raone SmartDimmer ?
    I'm wondering can I install smartdimmer insted of my existing wall swich ?
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 12-17-2008 1:07 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Re: New intelligent lightdimmer for B&amp;O remotes
    Quim
  • 12-17-2008 9:34 AM In reply to
    ballade:
    Now that's a showroom installation Stick out tongue
    Looks good otherwise.
    -mika
  • 03-18-2009 10:04 AM In reply to
    My query about both of these solutions is that of the wall switch.  I realise for my ceiling light, I could bypass the wall switch and control it only with the Beo4.  The device woul dbe mounted on the ceiling - so the touch switch would be useless, unless I had a ladder!
    Ideally, I would like to retain the option of turning the light on/off/dim from the wall.  How else would you find a Beo4 in the dark?!
    I can see a possibility of using a Z-Wave wall switch with the RAOne.  Does anyone have any other ideas?
  • 03-18-2009 12:39 PM In reply to
    • stefan
    • Posts 1,733
    You can mount the AluDim near the wall switch and control (dim and switch) your ceiling light via the black button  of the AluDim.
    Stefan
  • 03-18-2009 5:58 PM In reply to
    • Beogen
    • Top 500 Contributor
    • Joined on 05-12-2007
    • Belgium
    • Posts 135
    Does anyone has experience with this product:
    http://cms.jbmedia.de/index.php?option=com_content&task=view&id=95&Itemid=74
    You can order it in a B&O version with plasma protected receiver. I'm willing to order one but I'm a little afraid it won't have the same IR reception as a LC2.
    This makes it even more interesting for me, since you can make your existing light switches B&O ready.
    http://cms.jbmedia.de/index.php?option=com_content&task=view&id=79&Itemid=74&lang=en
  • 07-05-2009 1:43 PM In reply to
    Does anyone know why the links to the shop do not work?????
  • 07-05-2009 2:03 PM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Try here
    Quim
