Latest post 03-19-2008 12:45 PM by timmer66. 8 replies.
Page 1 of 1 (9 items)
  • 03-14-2008 9:37 AM
    • timmer66
    • Not Ranked
    • Joined on 03-03-2008
    • Polson, MT
    • Posts 36
    Beocenter 9000 connectivity
    I am considering buying a Beocenter 9000, and I have two questions.  First, will my Beogram 4002 (with built-in quad decoder) plug into it?  I realize it won't have remote capability, but will the 4-channel circuitry interfere?  Would I simply leave it set on 2-channel?
    Second, I see the Beocenter 9000 has an RCA "PRE AMP OUT" on the back.  Would I be able to plug this into my NAD preamp as an AUX, and play the CD/tape/phone through the Beocenter?    Or am I way off base here......
    Filed under: , , ,
  • 03-16-2008 6:54 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Beocenter 9000 connectivity
    Anyone?
    I'm not too au-fait with the vintage kit and it's compatability, but someone must know!
    Smile
  • 03-16-2008 1:44 PM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    In answer to your first question I don't see any problem in connecting your Beogram 4002. When I had a Beocenter 9000 I also had a Beogram 4002 connected to it for a while. Only difference been I did not have the decoder in mine. As for the pre out it is two Phono (RCA) connections that you could connect to your second Amp. It is even controlled by the volume of the Beocenter.
    CraigSmile
  • 03-16-2008 1:56 PM In reply to
    Actually there is an issue here. The CD4 circuitry does two things: it decodes the rear channels and send these signals to the two pins unused in the 5 pin DIN plug. This is not a problem but is best kept switched off as otherwise you cut off the frequencies above 15 kHz on the front channels.
    However the bigger issue is that it also amplifies and equalises the output to line level. Therefore you need to use the Aux or Tape2 input.
  • 03-16-2008 6:05 PM In reply to
    • Craig
    • Posts 4,855
    Peter :
    Is this the case for all Beograms with CD4 cicuitry?
    CraigSmile
  • 03-16-2008 6:24 PM In reply to
    Yes.
  • 03-17-2008 3:59 PM In reply to
    • Craig
    • Posts 4,855
    Thanks Peter, so I can connect my Beogram 4004 straight to my Beosound 3000 then. Useful to know.
    CraigSmile
  • 03-17-2008 4:01 PM In reply to
    Best Beogram with a RIAA in my opinion! Laughing
  • 03-19-2008 12:45 PM In reply to
    • timmer66
    • Not Ranked
    • Polson, MT
    • Posts 36
    Thanks for the information - the offer I made on the 9000 was accepted, so I'm looking forward to getting all this in place and singing!
