I have an odd problem, which I hope someone in here can help me with.
I have a masterlink installed in my house. In my main room I have a BV7-32 and BS3000 with BeoLab 6000. In my bedroom I have a BV6-22. Everything works just perfect.
Today I then bought an old used Avant 28" VCR for our guestroom and I connected that to my masterlink. My problem is that it seems I can't get the link to work on the Avant in the guestroom.
TV and V.TAPE is working, as these are local sources. But all the link sources DTV, DVD, Radio and CD does not work! I simply can't get these link sources to work on my Avant in my linkroom (in the guestroom). I then thought that it might because the Avant needed to be set to Option 6. However I can't set the option either!
I have no idea how old the Avant is. But it is an Avant 28" VCR, type 8111, serial no 11186598. It seems to be a local problem with the Avant only, as I have no problem in other linkrooms. The masterlink cable/connection for my guestroom also works, as I have tried the connection with an other TV as well.
This makes me wonder if my Avant actually does support Masterlink (I assume it would, as it has a masterlink connection + and RF output)
An other problem I now also realized on the Avant is that when watching TV and V.TAPE there are red horizontal lines on the screen. These are visible when the picture is dark (i.e. when you watch evening / dark scenes in a movie). When I bought this used Avant, I was told that the tube was replaced in Dec. 2001
1) Anyone who can help me with my linkproblem? How can I get it to work? How can I set the Avant to work in a linkroom?
2) And, anyone who knows why I have red horizontal lines on the screen? And what I can do about it?
3) Anyone who knows how old my Avant is? Which year is it from?
Thanks and regards,
Lars.
