Latest post 03-07-2008 3:05 PM by Medogsfat. 6 replies.
Page 1 of 1 (7 items)
  • 03-06-2008 4:45 AM
    Beolink 5000 two way fault?
    Hi, I just picked up a Nice beolink 5000 but after setting it up, doesn't seem to work in two-way mode with Beomaster 5500, which I'm sure it should. Just says 'No Contact'  and I don't know if this is because the receiving side of the BL5000 is not working.  The Beomaster is working fine two way with Master Control Panel.  Was the Beolink 5000 compatable with the BM5500?
    Jack
    BV10(40) BV8-32, BV3-32, MX7000, DVD1, HDR1, V8000
    Beomedia-1, BS9000, BC7002, BC2300, BS5500, BM6500, BGCD6500, BM1900-2
    BL5, BL8000, BL6000, BL Penta3, BL3500
    Beovox MC120.2, 3000 Panels, CX50s, C75s, AND LOTS WIRES, BOOkS, MAGS n BITS (ebay sales: beo-store-uk)
  • 03-06-2008 6:48 AM In reply to
    Re: Beolink 5000 two way fault?
    The BL5000 is not suitable for two way use with BM5500 as far as I recall.
    It may work in 1 way mode like a BL1000 provided that the 5500 has Beolink enabled software.
    Regards Graham
  • 03-06-2008 7:08 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Grahams right - it isn't compatible with the BM5500 in either 1 or 2 way mode.Sad
    Chris.
  • 03-06-2008 8:23 AM In reply to
    It does work OK in one-way mode with BM5500, for the record.  I don't have any other two way kit to truly test but wanted to be sure the BL5000 was not faulty before I get rid of it agian, if no use to me as it stands.  Ta.
    Jack
  • 03-06-2008 1:10 PM In reply to
    • Medogsfat
    • Posts 4,045
    Well there you have it! I'm wrong againEmbarrassed
    I was really going by past experience as my BM5500 didn't work with my BL5000 in either mode. Looks like Graham is correct in his beolink comment.
    Chris.
  • 03-06-2008 2:44 PM In reply to
    Medogsfat:
    Chris.
    It's the doubting that really hurts![:'(]
    Regards Graham
  • 03-07-2008 3:05 PM In reply to
    • Medogsfat
    • Posts 4,045
    joeyboygolf:
    Medogsfat:
    Chris.
    Sorry Mr Graham - I'll go and stand in the corner with my pointy "D" hat on.Confused
    Chris.
