Beobres
One other point. If you need to permanently use the vga socket which is sited on the temporary connection panel say for beomedia1 or an xbox etc, you will need to get a very shallow vga scocket as a normal vga cable is too big to allow the access panel door to close, and the associated phono cables / spdif cable also prevent closure of the door (i have not found a solution to that), so if you need to use these sockets you will see some cables at the top and the panel will need to be open all the time.
Regards
Peter
My B&O - BS3, BV4-50, Beomedia 1, BS3200, DVD1, BL8000, BL6000, BL3, BL2, BL7.4
