Ok all, thanks for all your responses and debates especially Dave Moulton.
I went off to our local DIY store and got 4 650 mm square concrete pavers.Two sandwiched together to make a concrete plinth about 5 inches high. Placed the Lab 5s on these. Re calibrated and then used a couple of B&O demo CDs to test any change. I also played the DTS DVD Terminator 3. Not much change at all. Interestingly I did noticed by standing right next to the lab 5s that (when they were on the concrete plinths and without being on them too) that when the calibration sequence started for the bass frequencies I could lliterally feel the floor boards deflecting.
Now Dave Moulton asked a very focussed question. The size of the joists supporting the floor. Well, (don't do this at home) I had to go off to our local pest control, get some "spider dispersal bombs" let them off under the house. Then wait an hour before crawling underneath. The gap is just over 24". The floor joists are solid hardwood, 6" x 8". The floor itself is solid hardwood boards 3/4" thick.
So, I took the lab5s off the plinths, then placed the US "Big Fat Dots" speaker vibration damping pads (note these can be used for speakers up to 90 kilos). Re calibrated, then played the same tracks and DVD.
Result - A HUGE DIFFERENCE, POSITIVE of course. I anticipated that it would be better, as when I started the calibration I stood next to the speakers and did not notice MUCH deflection of the floor boars all though there was a hint of it. I re calibrated again and this time sort of leaned on the larger aluminium disc of the lab 5s. Now no deflection of the floors.
End result, the 5s are back to their best. !!!!!!!
I actually took a day off work today to enjoy them, just to celebrate.
Herbies Audio Lab. They are on the web. $ US 70 + $US 25 postage to Australia. for 10 discs. $ placed in a square and one in the centre.
Hope this helps anyone else with the same problem.
Peter
