I have noticed that my Beogram 4002 tone-arm has a considerable back and forth motion during play. I would guesstimate that it is as much as 4mm of side to side movement. By comparison my Beogram 4000 has a back and forth movement of say 2mm or less.
So is the normal?
When I first received the 4002 I noticed that the 20EN cartridge had a great deal of movement as well and decided that the shaft must be broken and I replaced it with a 20CL which does not move.
The sound quality is excellent and there is no skipping, but I was wondering if something is amiss or requires adjustment.
What do you think?
Jeff
