1st March February 2012
Latest post 06-17-2008 3:05 AM by Ben. 18 replies.
03-01-2008 1:02 PM
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Beogram 4004 - Arm fails to lower!!!!!
Need some advice with a Beogram 4004 I have just purchased. When I plugged it in I could hear the motor running but the platter would not turn. Just found the that the belt had come off, so an easy fix. Fitted it with an MMC10 stylus just to try it out. When I press play the arm moves to the start of the record but fails to lower. You can hear a click from inside which I assume is the solenoid working. If I remove the panels and try to use the raise and lower button I can see the solenoid moving. Tracking weight is set at 0.5g. Is this a simple fix? fingers crossed. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Peter
- Joined on 02-12-2007
- Posts 9,572
Re: Beogram 4004 - Arm fails to lower!!!!!
First thing - check the tracking weight is not set to zero. If it is set properly, it will need cleaning and lubricating.
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
It could well be the linkage between the solenoid & the tonearm Craig. You should be able to move it quite freely by hand. There are several pivot points which cease up over time. Just take it apart, clean the old lube off & reassemble with a touch of silicon grease. Not difficult to do & the linkage is fairly easily accessable. Chris.
Craig
- Posts 4,855
How do I get the cover off that covers the two arms? Or can I clean all the parts with this in place? Craig
Medogsfat
- Posts 4,045
Craig, if you view page 3-2 "adjustment of magnet coil" diagram in the service manual you can see the see saw (possibly pantograph??) arrangement of this assembly. It is the pivot points which can become stiff. It's a while since I did this on a BG4000 (same system) and I think I had to disconnect the solenoid first - not sure though. Martin will probably know. You shouldn't need to remove the cover to do this. Chris. EDIT:- try not to lose the screws eh?
Craig
- Posts 4,855
Cheers Chris, I will take a look later tonight, just got to pop out for an hour so. You might be getting a phone call if I get stuck. Craig
Medogsfat
- Posts 4,045
You'll be fine mate. It's pretty straightforward once you make a start. Chris.
Craig
- Posts 4,855
Medogsfat: You'll be fine mate. It's pretty straightforward once you make a start. Chris.
It was very straight forward, once I got inside it. Cleaned all the old glue grease off. Even managed to get some silicon grease from my Dad last night (Seems that it also used on some models of cars for the ignition leads). Also greased the brass worm drive thing that moves the arm. It will need a set of new belt as the small one that drives the arm has stretched quite a bit. My plan was to replace these anyway, so I will see if Martin has some in stock. Just need to hook it up to my BS3000 to try it out the stylus I fitted as I am not sure of it's condition. May even treat it to a nice new SMMC20EN. Craig
Craig
- Posts 4,855
Well I may have celebrated a bit too early. Now the arm loweres most of the time, seems to be getting better with more use. So I will see how that goes for now. My next problem is that when the arm gets to the ned of the record is does not return or lift. If I use the < button it goes to the end of it's travel and returns perefectly. tried cleaning the sensor lamp to see if that made any difference, but it did not. Craig
Craig
- Posts 4,855
NOOOOOOO. Things seem to be going from bad to worse with this one. Just thought I would have a listen to a record on it. So I connected it to my Beomaster 900. Pressed start now the arm goes all the way along to the end and returns. It won't even work with the up and down buttons. It is as if it cannot see the record. Could this be a problem with the lamp? Craig
kevinoils
- Joined on 11-11-2007
- Posts 62
Hi Craig I have had similiar problems with the sensor adjustment, but inside the sensor arm i have repositioned the bulb closer to the lense. It seems that the end of the arm the small plastic part with the legend on opens easily and can be slid out far enough to carefully reposition it. The tone arms tracking to the centre I have experienced problems with this but adjusted the sensor and it has stabalised the motor and the arms tracking movement. I hope this makes sense. Cheers Kevin
Craig
- Posts 4,855
Thanks Kevin, I will give it a go and see what happens. Craig
kevinoils
- Posts 62
Oh Craig I forgot to mention the solenoid adjustment at the base of the tone arm can be very tricky to adjust but there are loads of threads on Beoworld describing this, the slightest movement left or right can make the arm track backwards it seems or scanning towards the centre. It may be that you can do tiny adjustments to this until it tracks better and then tighten up again. I have to stress though this is a patience job, and it can take a while to get right. Cheers Kevin
Craig
- Posts 4,855
Thanks again Kevin, I have not had a chance to look at it since you last post. When I do I will try both, although I am sure it is the lamp that is the problem as the solenoid does not even try to move now. Craig
kevinoils
- Posts 62
Hi Craig I realised I said adjustment of solenoid, when I meant moving the diaphragm by lossening screw at base and moving this left and right slightly, its in the Beogram 4002-4004 manual sect 3-5 Hope you got this sorted! Cheers Kevin
Craig
- Posts 4,855
Still not got round to sorting it out yet Kevin, but thanks for the update. Craig
Ben
- Joined on 12-28-2007
- Taunton, UK
- Posts 131
Ok, so this is now my Beogram! I cleaned the light lense as it was all murky, and have tried various positions for the lamp inside the arm, but it still fails to 'see' the record. The arm goes across the LP, the speed changes to 45, hits the end, then returns. I read that a marginal lamp can cause problems, this one still looks ok though. Any thoughts?
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
It's actually the rotating stripes the sensor arm is trying to see, not the record. If the lamp/sensor system wasn't working, the arm would lower on the platter! Therefore, I think your problem is in the logic following the sensor, not in the sensor arm. Something in the sensor signal filter / amplifier, or after its output, is "stuck" in the position where the rest of the logic thinks the platter signal is seen by the sensor. A failed diode, or something?
Ben
- Taunton, UK
- Posts 131
Ok, So i've made a bit of progress... not meaning to though. I took the main PCB out, to check for burned components, put it back in, and the arm will now will drop at the 12" LP position. Moving the tonearm to the left though, the carriage will not follow, so there are still some glitches. If I put on a single, the arm still decides to drop at the LP position. I'm thinking along the lines of recapping and seeing what happens after that. Does anybody have a clearer version of the service manual? I can't read the schematics on the one on here. Thanks, Ben
Page 1 of 1 (19 items)
