Latest post 06-17-2008 3:05 AM by Ben. 18 replies.
Page 1 of 1 (19 items)
  • 03-01-2008 1:02 PM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Beogram 4004 - Arm fails to lower!!!!!
    Need some advice with a Beogram 4004 I have just purchased. When I plugged it in I could hear the motor running but the platter would not turn. Just found the that the belt had come off, so an easy fix. Fitted it with an MMC10 stylus just to try it out. When I press play the arm moves to the start of the record but fails to lower. You can hear a click from inside which I assume is the solenoid working. If I remove the panels and try to use the raise and lower button I can see the solenoid moving. Tracking weight is set at 0.5g. Is this a simple fix? fingers crossed.
    CraigSmile
  • 03-01-2008 1:26 PM In reply to
    Re: Beogram 4004 - Arm fails to lower!!!!!
    First thing - check the tracking weight is not set to zero. If it is set properly, it will need cleaning and lubricating.
  • 03-01-2008 2:09 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    It could well be the linkage between the solenoid & the tonearm Craig. You should be able to move it quite freely by hand. There are several pivot points which cease up over time. Just take it apart, clean the old lube off & reassemble with a touch of silicon grease. Not difficult to do & the linkage is fairly easily accessable.
    Chris.
  • 03-01-2008 2:18 PM In reply to
    • Craig
    • Posts 4,855
    How do I get the cover off that covers the two arms? Or can I clean all the parts with this in place?
    CraigSmile
  • 03-01-2008 2:35 PM In reply to
    • Medogsfat
    • Posts 4,045
    Craig, if you view page 3-2 "adjustment of magnet coil" diagram in the service manual you can see the see saw (possibly pantograph??) arrangement of this assembly. It is the pivot points which can become stiff. It's a while since I did this on a BG4000 (same system) and I think I had to disconnect the solenoid first - not sure though. Martin will probably know.
    You shouldn't need to remove the cover to do this.
    Chris.
    EDIT:- try not to lose the screws eh?Stick out tongue
  • 03-01-2008 2:39 PM In reply to
    • Craig
    • Posts 4,855
    Cheers Chris, I will take a look later tonight, just got to pop out for an hour so. You might be getting a phone call if I get stuck.Wink
    CraigSmile
  • 03-01-2008 2:41 PM In reply to
    • Medogsfat
    • Posts 4,045
    You'll be fine mate. It's pretty straightforward once you make a start.Wink
    Chris.
  • 03-02-2008 10:26 AM In reply to
    • Craig
    • Posts 4,855
    Medogsfat:
    Chris.
    It was very straight forward, once I got inside it. Cleaned all the old glue grease off. Even managed to get some silicon grease from my Dad last night (Seems that it also used on some models of cars for the ignition leads). Also greased the brass worm drive thing that moves the arm. It will need a set of new belt as the small one that drives the arm has stretched quite a bit. My plan was to replace these anyway, so I will see if Martin has some in stock. Just need to hook it up to my BS3000 to try it out the stylus I fitted as I am not sure of it's condition. May even treat it to a nice new SMMC20EN.Laughing
    CraigSmile
  • 03-02-2008 11:05 AM In reply to
    • Craig
    • Posts 4,855
    Well I may have celebrated a bit too early. Now the arm loweres most of the time, seems to be getting better with more use. So I will see how that goes for now. My next problem is that when the arm gets to the ned of the record is does not return or lift. If I use the < button it goes to the end of it's travel and returns perefectly. tried cleaning the sensor lamp to see if that made any difference, but it did not.
    CraigSmile
  • 03-03-2008 2:36 PM In reply to
    • Craig
    • Posts 4,855
    NOOOOOOO. Things seem to be going from bad to worse with this one. Just thought I would have a listen to a record on it. So I connected it to my Beomaster 900. Pressed start now the arm goes all the way along to the end and returns. It won't even work with the up and down buttons. It is as if it cannot see the record. Could this be a problem with the lamp?
    CraigSmile
  • 03-06-2008 9:19 AM In reply to
    Hi Craig
    I have had similiar problems with the sensor adjustment, but inside the sensor arm i have repositioned the bulb closer to the lense. It seems that the end of the arm the small plastic part with the legend on opens easily and can be slid out far enough to carefully reposition it.
    The tone arms tracking to the centre I have experienced problems with this but adjusted the sensor and it has stabalised the motor and the arms tracking movement.
    I hope this makes sense.
     Cheers
    Kevin
  • 03-06-2008 1:52 PM In reply to
    • Craig
    • Posts 4,855
    Thanks Kevin, I will give it a go and see what happens.
    CraigSmile
  • 03-13-2008 10:29 AM In reply to
    Oh Craig
     I forgot to mention the solenoid adjustment at the base of the tone arm can be very tricky to adjust but there are loads of threads on Beoworld describing this, the slightest movement left or right can make the arm track backwards it seems or scanning towards the centre. It may be that you can do tiny adjustments to this until it tracks better and then tighten up again.
    I have to stress though this is a patience job, and it can take a while to get right.
    Cheers
     Kevin
  • 03-13-2008 4:06 PM In reply to
    • Craig
    • Posts 4,855
    Thanks again Kevin, I have not had a chance to look at it since you last post. When I do I will try both, although I am sure it is the lamp that is the problem as the solenoid does not even try to move now.
    CraigSmile
  • 04-05-2008 7:35 AM In reply to
    Hi Craig
     I realised I said adjustment of solenoid, when I meant moving the diaphragm by lossening screw at base and moving this left and right slightly, its in the  Beogram 4002-4004 manual sect 3-5
    Hope you got this sorted!
     Cheers
     Kevin
  • 04-05-2008 12:04 PM In reply to
    • Craig
    • Posts 4,855
    Still not got round to sorting it out yet Kevin, but thanks for the update.
    CraigSmile
  • 06-16-2008 1:28 PM In reply to
    • Ben
    • Top 500 Contributor
    • Joined on 12-28-2007
    • Taunton, UK
    • Posts 131
    • Silver Member
    Ok, so this is now my Beogram!
    I cleaned the light lense as it was all murky, and have tried various positions for the lamp inside the arm, but it still fails to 'see' the record. The arm goes across the LP, the speed changes to 45, hits the end, then returns.
    I read that a marginal lamp can cause problems, this one still looks ok though.
    Any thoughts?
  • 06-16-2008 2:24 PM In reply to
    It's actually the rotating stripes the sensor arm is trying to see, not the record. If the lamp/sensor system wasn't working, the arm would lower on the platter! Therefore, I think your problem is in the logic following the sensor, not in the sensor arm. Something in the sensor signal filter / amplifier, or after its output, is "stuck" in the position where the rest of the logic thinks the platter signal is seen by the sensor. A failed diode, or something?
    -mika
  • 06-17-2008 3:05 AM In reply to
    • Ben
    • Taunton, UK
    • Posts 131
    • Silver Member
    Ok, So i've made a bit of progress... not meaning to though.
    I took the main PCB out, to check for burned components, put it back in, and the arm will now will drop at the 12" LP position.
    Moving the tonearm to the left though, the carriage will not follow, so there are still some glitches. If I put on a single, the arm still decides to drop at the LP position.
    I'm thinking along the lines of recapping and seeing what happens after that.
    Does anybody have a clearer version of the service manual? I can't read the schematics on the one on here.
    Thanks,
    Ben
