Latest post 02-29-2008 12:58 PM by solderon29. 5 replies.
Page 1 of 1 (6 items)
  • 02-28-2008 1:10 PM
    Vintage Beovision LX 2500 A/V tuning
    Hi everyone,
    I am having a problem with my B&O tv getting the A/V picture to stabalise. I have the original Mk3 remote and user manual and have tried to follow the instructions. I have sussed that the AUX is the shift key but I am struggling with what the Control key is in the manual, I assume that all the functions can be used using the most advanced remote. I hope that someone out there has experienced this before and solved it and it is not a fault on my set. That would make me most upset as the rest of my vintage equipment works perfectly together. Please could somebody help me?
  • 02-28-2008 1:31 PM In reply to
    Re: Vintage Beovision LX 2500 A/V tuning
    Do you mean with mk3 the Beolink1000mk3?
    I ask this because the original remote that came with the LX2500 was the V-terminal or AV-terminal.
    If it's the Beolink1000, did you try [GOTO] or [SHIFT] [GOTO]
  • 02-28-2008 3:47 PM In reply to
    I think it might be Shift tv 2,to stabilse the picture?
  • 02-28-2008 6:40 PM In reply to
    solderon29:
    Yes you're right [SHIFT] [TV] [2] is to select the scart.
    [SHIFT] [TV] [3] is to select to 6-pin A/V connector
    But there was also a [CONTROL] key on the V-terminal and I think that he's trying to find out how that works on the Beolink1000.
    I don't think that there's a key combination on the Beolink1000 for that.
    I used to have a Beolink7000 with a [CONTROL] key, but I never found that function on the Beolink1000.
  • 02-29-2008 12:53 PM In reply to
    Ah yes! I remember now,it's to stabilise video signals,and can be set per preset,but I'm not sure it works on the av inputs?Try it anyway.
    Via the Beolink 1000,it's TV-Shift-2-Store-Store,to set a preset,and an A/V symbol then appears in the onscreen display.
    Regards,
    Nick
  • 02-29-2008 12:58 PM In reply to
