solderon29: I think it might be Shift tv 2,to stabilse the picture?
Yes you're right [SHIFT] [TV] [2] is to select the scart.
[SHIFT] [TV] [3] is to select to 6-pin A/V connector
But there was also a [CONTROL] key on the V-terminal and I think that he's trying to find out how that works on the Beolink1000.
I don't think that there's a key combination on the Beolink1000 for that.
I used to have a Beolink7000 with a [CONTROL] key, but I never found that function on the Beolink1000.
