1st March February 2012
Latest post 02-29-2008 2:36 PM by joeyboygolf. 10 replies.
02-28-2008 11:55 AM
rfc1
- Joined on 02-06-2008
- Posts 166
Beosund 9000, Beogram compatability
Do i need a Beogram with built in RIAA amp to use through my beosound 9000 with Beolab 6000 speakers? Or not? Sandy
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Re: Beosund 9000, Beogram compatability
Yes you will, or get an external RIAA. Just remember that you will not be able to control the Beogram via Datalink. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
The Beosound 9000 does not have datalink so that will not be a problem. To plug in direct you need a Beogram 3500, 4500, 6500 or 7000. To go via external RIAA you can use virtually any of the others.
Craig
- Posts 4,855
joeyboygolf: The Beosound 9000 does not have datalink so that will not be a problem.
That is what I meant. Craig
mobeyone
- Joined on 03-27-2007
- UK
- Posts 955
I think Ridax made a little plug in thing (sorry for the technical term!) which allowed you to control a beogram from your remote.
Craig
- Posts 4,855
joeyboygolf:Sorry Craig, I misunderstood. My wife says I do a lot of that!!
Strange, I get that too.    Craig
Craig
- Posts 4,855
mobeyone:I think Ridax made a little plug in thing (sorry for the technical term!) which allowed you to control a beogram from your remote.
You are correct Mobe. Here is a link to the item in question. Ridax's little plug in thing Craig
rfc1
- Posts 166
So i take it also that it doesnt matter that the Beolab 6000 speakers have built in Amplifiers, i still need either a built in Amp in Record deck or external amp ?? cheers sandy
Page 1 of 1 (11 items)
