Hi Peter,
Thanks for the reply.
I looked behind the set and found a sticker, it says 'Acc' but nothing is listed after it, the dealer i bought it from stated it had anti reflex screen but i wanted to double check, is there any other way of telling?
I found two input sockets on the back of the set, i presume these are the ones that you mentioned, which means that i have to obtain a digital optical out to analogue wire?
Sorry for being ignorant but how do i get into the service menu and where would the film mode be listed?
Really sorry about all the questions Peter.
