1st March February 2012
Latest post 02-23-2008 5:25 AM by Peter. 16 replies.
02-22-2008 2:35 PM
rfc1
- Joined on 02-06-2008
- Posts 166
Help please, Beosound 9000 wont work.
Right, i have mounted and wired my beosound 9000 and beolab 6000's up. Problem is i cannot get the cd's to play, the clamper moves up and down ok, seems to release the cd's from the jaws holding them, but then does nothing and displays "pause" after a few moments..... Whats up???? sandy
mobeyone
- Joined on 03-27-2007
- UK
- Posts 955
Re: Help please, Beosound 9000 wont work.
Have you turned the 2 screws for the cd mech on the back in the right direction?
marcus_m
- Joined on 04-16-2007
- Bavaria
- Posts 470
Are the two screws on the back set up correct? Marcus
rfc1
- Posts 166
Guys 99% sure they are correct, will now double check, although i dont think they would stop the cd unit functioning though if set wrongly.?? thanks sandy
mobeyone
- UK
- Posts 955
Think so.. as I doubt the laser is aligned correctly to read the cd? or for some other reason but even if one is slightly out it may not read. Failing this, give it a good clean, both black shiny plastic pieces either end of the changer.
joeyboygolf
- Ely, Cambridgeshire, UK
- Posts 3,252
Your symptoms would appear to have nothing to do with the two settings under the 9000. These merely centre the whole cd mechanism relative to the chassis when the unit is placed in different orientations. Things that can cause this symptom include:- Dusty IR safety beam - Clean the clear plastic pyramids either end of the CD bed. These are designed to prevent the unit operating if fingers etc are in the area. Dusty CD laser lens - A bit difficult to get at unless you know what you are doing. The service manual is on site for silver and gold members and this gives instruction. Some people have reported success with CD cleaning discs but I have my doubts! Knackered CD mechanism. Let us know how you get on.
rfc1
- Posts 166
All looks clean, the cd's simply wont spin round! The thing only arrived from lifestyle av yesterday, so shouldnt be problematic surely? sandy
joeyboygolf
- Posts 3,252
rfc1: All looks clean, the cd's simply wont spin round! The thing only arrived from lifestyle av yesterday, so shouldnt be problematic surely? sandy
Aah! You didn't say that before. Don't meddle with it. Phone Lee at LifeStyle-AV. That is what the warranty is for.
rfc1
- Posts 166
Sorry should have said, dont worry i am not a meddler, just wanted to make sure i hadnt missed something obvious during set up .. thanks sandy
archie
- Paris
- Posts 497
Did you ear some 'click' from the cd mecanism when the disc try to spin ?
rfc1
- Posts 166
yes, it does click. sandy
archie
- Paris
- Posts 497
i affraid than you must changed the "optical block". In france the price is 110 euros only for this :
Peter
- Joined on 02-12-2007
- Posts 9,572
Big advantage of a warranty!
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
Out of interest - can this be easily damaged in transit? The unit was tested before it left, and only sat in bubble wrap with a quilt round it whilst it was driven from our shop to Scotland.. Never happened before - quite worrying! As Peter has mentioned, all covered by warranty though. Lee
Peter
- Posts 9,572
I am sure this is just bad luck. You never know, another journey and it might work! The optical heads on these are reported to be a little prone to fail.
joeyboygolf
- Posts 3,252
Lee Despite other posts to the contrary, you are not the almighty!! These items are complex pieces of mechanical/optical/electronic equipment. Somewhere in the advertising they do state how many component parts the 9000 contains. With the best will in the world, things do fail. Everybody should live with that 'cos to deny it is folly!
Page 1 of 1 (17 items)
