1st March February 2012
Latest post 02-27-2008 11:03 AM by Coolskin. 15 replies.
02-22-2008 10:39 AM
Bv7Mk3
- Joined on 12-01-2007
- Posts 272
I have a new Bv 7Mk3 which has a fab picture on it but due to Issues with hand shaking with my projector (Jvc Hd1) is going back  I have tryed Two beosystem 3's which work ok with my projector!  Can someone advise as to what screen I can use with the beo system 3 which is non be & o around the 40 to 50 inch size! please and maybe the cost if known! Thanks.
Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Off Topic ... You might want to change your user name....
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
chrisped
- Joined on 04-17-2007
- Oslo
- Posts 125
If you are looking at the panasonic range, which are the panels inside the BV 4 you have the following options: TH42PH10 - Commercial panel (no speakers or tuner) non full hd - approx £750
TH50PH10 - Commercial panel (no speakers or tuner) non full hd - approx £1350 TH50PF10 Commercial panel (no speakers or tuner) FULL HD - approx £2000 PH10's comes in black or silver, PF10 comes in black only. They should all work very well with the BeoSystem 3. The PF10 supports 24Hz/p with the HDMI board, but unfortunately we are still waiting for the BeoSystem 3 to support this nice / must have feature. I am considering buying a PF10 for my BeoSystem 3. Christian
kawo
- Posts 516
I have both a TH-50PH and a JVC HD1. No handshaking problems with both (furtunately). The advantage of the Panasonic commercial line is the RS232 control by the BS3. However, if you are able to strech your budget a little bit further you should take a look at the new Pioneer Kuro line up. Black levels are breathtaking! (and the look is nicer (imho) compared to the Pani) Karsten
_________________________________________________________________________
BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
ed7
- Joined on 12-06-2007
- uk
- Posts 297
TerryM
- Posts 208
kawo: I have both a TH-50PH and a JVC HD1. No handshaking problems with both (furtunately). The advantage of the Panasonic commercial line is the RS232 control by the BS3. However, if you are able to strech your budget a little bit further you should take a look at the new Pioneer Kuro line up. Black levels are breathtaking! (and the look is nicer (imho) compared to the Pani) Karsten
Hi, do you know if the Beosystem 3 works with the Pioneer Kuro(8G) series? I was contemplating this combination,but when I telephoned B & O UK,the response to my enquiry was a curt "Not recommended". Does a Beosystem 3 not act like any other external preamp/processor? My local dealer has offered to bring a Beosystem 3 for me to try,but I don't want to bring him on a wasted journey if B & O UK are correct.
Bv7Mk3
- Posts 272
Terry M,just let your dealer set one up at home and try it out I did and was impressed.B & O will say that dont support this and that. I have a new Bv7 Mk3 which will not run with my projector but the two bs 3 that I tryed out work ok and others have the same pj as me with the bs3 and there fine also.Its a case of try out first and seeing! You dealer will understand and the b3 is a great system. My Dealer has been so helpful with my problem and hope to have something sorted very soon
kawo
- Posts 516
TerryM:Hi, do you know if the Beosystem 3 works with the Pioneer Kuro(8G) series? I was contemplating this combination,but when I telephoned B & O UK,the response to my enquiry was a curt "Not recommended". Does a Beosystem 3 not act like any other external preamp/processor? My local dealer has offered to bring a Beosystem 3 for me to try,but I don't want to bring him on a wasted journey if B & O UK are correct.
In theory the BS3 should act like any other processor, as always with B&O the devil is in the detail....best would be if you would test this combo at home. The biggest challenge I have in the moment (SW4.00a) is that the projector does not work with 1080p 50Hz, only with 60Hz and a challenge with the different black level ranges of the input/output which result in limited difference in the black/grey levels. Only a test could help! Karsten
TerryM
- Posts 208
Bv7Mk3,and kawo, many thanks for you comments. I was very impressed with a lengthy shop demo of the beosystem 3 that I had late last year,so I will arrange for a home demo. Assuming there are no problems,it will be interesting to compare the Beosystem 3's processing against that of my Pioneer LX608. Terry.
Bingo
- Posts 922
What I don't understand is when I read here that the Kuro plasma panel gives a much more beautiful picture in combination with the Beosystem 3 then the Panasonic panel, why does B&O not use a Kuro Panel ? I thought they wanted to give their clients the best picture experience available?
V13WNG
- Joined on 06-11-2007
- Eastbourne, East Sussex, ENG
- Posts 200
Aren't the Panasonic units which make up the BV4 slightly upgraded to those found in Comet and Curry's? I alsways thought that the manufacturers of the "Donor" screens had to sign a clause stating that they weren't allowed to use the technology in their own units?
Muchos Gracias
TerryM
- Posts 208
A14BEO: Aren't the Panasonic units which make up the BV4 slightly upgraded to those found in Comet and Curry's? I alsways thought that the manufacturers of the "Donor" screens had to sign a clause stating that they weren't allowed to use the technology in their own units?
It is my understanding that B & O use a Panasonic commercial (PF/PH?)panel,but whether,or not,it is manufactured to B & O's quality control standards I cannot say. I gather that Panasonic's commercial panels are more suited than it domestic models to being used with an external processor. For me,the attraction of the Pioneer is not just the PQ-which is stunning-but also it's wide range of user adjustments,it's ability to handle 1080p/24,and the fact that it is capable of being ISF calibrated,and all for just over £5000 for the LX608. Hence my desire to use it with a Beosystem 3.
Coolskin
- Joined on 04-16-2007
- Holland
- Posts 505
Bv7Mk3:I have a new Bv 7Mk3 which has a fab picture on it but due to Issues with hand shaking with my projector (Jvc Hd1) is going back  I have tryed Two beosystem 3's which work ok with my projector!  Can someone advise as to what screen I can use with the beo system 3 which is non be & o around the 40 to 50 inch size! please and maybe the cost if known! Thanks.j
Customer Service Chat session:CustomerService, Bang & Olufsen [2/13/2008 1:34:00 PMCET] [#3563]Answer to post #3558 The modelsare Samsung SPH 700 & 800. Furthermore also SIM2 C3X Guido,Germany [2/13/2008 1:32:00 PM CET] [#3562] yesi see the button DTV CustomerService, Bang & Olufsen [2/13/2008 1:32:00 PMCET] [#3561]Answer to post #3559 You need topress the standby buttom and LIST at the same time and then you press GO untilit says ADD in the display and then you press LIST until you PC in the display,and save this. Coolskin,Netherlands [2/13/2008 1:31:00 PM CET] [#3560]@Guido, your BEO4 model should have a DTV button... Does it? Guido,Germany [2/13/2008 1:30:00 PM CET] [#3559] ihave the beo4 button list "format" list "stand" list"speaker" list "p-and-p" list "AV" in theinstructions is speak for "PC" Coolskin,Netherlands [2/13/2008 1:30:00 PM CET] [#3558] @CS,#3556. Could you point out which models if you please? Coolskin,Netherlands [2/13/2008 1:29:00 PM CET] [#3557] @CS,thanks for the Power link MKIII cable suggestion. That's usefull information. CustomerService, Bang & Olufsen [2/13/2008 1:29:00 PMCET] [#3556]Answer to post #3553 It ispossible to connect a projector, but only two different models from Samsung aresupported by the BeoVision 7 Coolskin,Netherlands [2/13/2008 1:27:00 PM CET] [#3555]@Guido, do you use the most recent BEO4? I think only this BEO4 model has"PC" under LINK. CustomerService, Bang & Olufsen [2/13/2008 1:26:00 PMCET] [#3554]Answer to post #3551 You need toadd the PC in the LIST of your Beo4. You will find the instuction for this inyour user guide. Coolskin,Netherlands [2/13/2008 1:26:00 PM CET] [#3553] Ihave a prehistoric BV7 (version 2004) and like to hook up a beamer for fun.Just to see if this is something I like. If so I could investigate how to setup such kind of setup. Is my (old) BV7 equiped to handle the beamer?
Info about BV7-32 model 2004 and projectors. #3553, #3556, #3563
Page 1 of 1 (16 items)
