1st March February 2012
02-19-2008 1:57 PM
marcus_m
- Joined on 04-16-2007
- Bavaria
- Posts 470
Re: BV9+Playstation3+Beo5 = works perfect
Anders, if my mind serves me right, you did order an ir remote with usb receiver for the ps3, also. Did this work as well? Thanks, Marcus
mr_anders_son
- Joined on 03-27-2007
- sweden
- Posts 1,032
Yeah but it was very hard to get it from USA But I order one yesterday from USA at last, but I dont need it anymore ....LOL
marcus_m
- Bavaria
- Posts 470
Thanks. By the way, what is this tiny little picture you did attach to your initial post?!?
mr_anders_son
- sweden
- Posts 1,032
marcus_m: Thanks. By the way, what is this tiny little picture you did attach to your initial post?!?
The IR eye with USB that I use
krisb
- Joined on 01-29-2008
- Athens, Georgia, USA
- Posts 28
By the way, I've been wondering... has any one noticed the similarities between the design of the PS3 (I have one too) and some B&O equipment? It's got a bit of Beocentre 2200 about it + Beolab 4000's. Wonder whether they took inspiration from these at all?
mr_anders_son
- sweden
- Posts 1,032
chrisped: This looks very cool. Would this work in conjunction with the IR blaster setup with a BeoSystem 3? So I could complete hide the ps3 away somewhere?? (except for changing dvds)
Yes, I have my PS3 on the wall behind my BV9
mr_anders_son
- sweden
- Posts 1,032
chrisped: Would it have to be a Beo5 or could a Beo4 do a similar job since it will be using the IR blaster I guess I could choose Sony DVD player from the list?
Both remote works ofcourse ;-) But Beo5 is better to use in my opinion....
Trucker
- Joined on 04-22-2007
- Denmark
- Posts 33
Hi, Is PS3 on the STB-controllerlist in the TV ? Or how do you control the PS3 with the beo4.Is it play, stop, rewind when playing Blue ray? Trucker
mr_anders_son
- sweden
- Posts 1,032
Trucker: Hi, Is PS3 on the STB-controllerlist in the TV ? Or how do you control the PS3 with the beo4.Is it play, stop, rewind when playing Blue ray? Trucker
Yes BUT you must buy Nyko remote and you can not use on/off You can buy it only from USA or eBay I have this: www.schmatrz.com and it much better
Victor77
- Joined on 02-07-2008
- Posts 10
Anders, can you move through your music, pictures, etc... or does it only work with the movie menu? Thanks
BarryAndrew
- Joined on 09-07-2007
- Cornwall, UK
- Posts 72
Because I am not a gamer I have had no interest in the PS3. However now I am looking for a blu-ray player that has flexible outputs so that I can continue to use scart connection to my non-HD BV6-26. This would enable me to upgrade my DVD1 without forcing me to change the TV now. This is even better if you can control the darned thing with a beo4. Because I don't know this product at all can anyone explain the on/off switch thingy. You all, obviously, understand what is going on but I don't. Is the devise being talked about from schwartz an infra red on-off? which will work with an stb? Sorry for my ignorance but I have never owned a gaming machine.
Barry
BV6-26,BC2300,Beolab8000,4000,3500,2000,DVD1
mr_anders_son
- sweden
- Posts 1,032
Victor77: Anders, can you move through your music, pictures, etc... or does it only work with the movie menu? Thanks
100% use
mr_anders_son
- sweden
- Posts 1,032
BarryAndrew: Because I am not a gamer I have had no interest in the PS3. However now I am looking for a blu-ray player that has flexible outputs so that I can continue to use scart connection to my non-HD BV6-26. This would enable me to upgrade my DVD1 without forcing me to change the TV now. This is even better if you can control the darned thing with a beo4. Because I don't know this product at all can anyone explain the on/off switch thingy. You all, obviously, understand what is going on but I don't. Is the devise being talked about from schwartz an infra red on-off? which will work with an stb? Sorry for my ignorance but I have never owned a gaming machine.
I bought PS3 only to use it as BD player, but ofcourse you can use it with music, photos etc The Schmartz gadget is a ir receiver same as eg Nyko, BUT he has made it so you can use on/off PS3 use Bluetooth to pilot the consol, so if you want to use a IR remote you must have this If I where you I should stick with DVD1 until you buy a full HD
Luigi
- Figueres (Spain)
- Posts 3,013
Another interesting possibility can be OneRemote.
mr_anders_son
- sweden
- Posts 1,032
not for that price schmartz cost 30 dollar and 50 with on/off function
BarryAndrew
- Cornwall, UK
- Posts 72
The problem with waiting for the HD TV before you get the HD player is that you have to buy both at the same time. Getting one at a time enables you to get what you want which may be constrained with a double purchase. Does the one remote allow the same sort of access as the stb? In other words will it allow link room access? If I wanted the PS 3 and bought the one remote when its available in March would I need anything else or will that do the job? The one remote is more expensive but if it does the job then it looks tidier and the PS 3 does have a BL 4000 look to it.
Barry
Trucker
- Denmark
- Posts 33
Hi Anders, I have a BV7 mrk III and I can`t find the PS3 in the puc-list. I want to hide the PS3 in a cabin and use the schmartz and beo 4. How do I do ? Trucker
mr_anders_son
- sweden
- Posts 1,032
Trucker: Hi Anders, I have a BV7 mrk III and I can`t find the PS3 in the puc-list. I want to hide the PS3 in a cabin and use the schmartz and beo 4. How do I do ? Trucker
If you buy IR from Schmartz you shall not use PS3 in STBlist. It will only work with Nyko remote You shall choose a Sony DVD player. I shall look wich one I have in my list when I come home from work Your dealer can update your BV7 with ir generator
Page 1 of 1 (22 items)
