Latest post 02-20-2008 9:21 AM by mr_anders_son. 21 replies.
Page 1 of 1 (22 items)
  • 02-19-2008 1:57 PM
    BV9+Playstation3+Beo5 = works perfect
    Now I got my latest gadget. A little small piece so I can pilot my PS3 with Beo4/5. I bought it from schmartz.com
    I can 100% control PS3 AND on/off to!!!!
    I will return with some picture later
    All this for only 50 dollar ;-)
     link: http://www.schmartz.com/product.sc?categoryId=1&productId=4
  • 02-19-2008 2:41 PM In reply to
    Re: BV9+Playstation3+Beo5 = works perfect
    Anders,
    if my mind serves me right, you did order an ir remote with usb receiver for the ps3, also. Did this work as well?
    Thanks, Marcus
  • 02-19-2008 2:43 PM In reply to
    Yeah but it was very hard to get it from USA
    But I order one yesterday from USA at last, but I dont need it anymore ....LOL
  • 02-19-2008 2:48 PM In reply to
    Thanks. By the way, what is this tiny little picture you did attach to your initial post?!?
  • 02-19-2008 3:34 PM In reply to
    marcus_m:
    The IR eye with USB that I use
  • 02-19-2008 6:26 PM In reply to
    • krisb
    • Not Ranked
    • Joined on 01-29-2008
    • Athens, Georgia, USA
    • Posts 28
    By the way, I've been wondering... has any one noticed the similarities between the design of the PS3 (I have one too) and some B&O equipment?
    It's got a bit of Beocentre 2200 about it + Beolab 4000's.
    Wonder whether they took inspiration from these at all?
  • 02-20-2008 4:18 AM In reply to
    This looks very cool. Would this work in conjunction with the IR blaster setup with a  BeoSystem 3? So I could complete hide the ps3 away somewhere?? (except for changing dvds)
  • 02-20-2008 4:30 AM In reply to
    chrisped:
    Yes, I have my PS3 on the wall behind my BV9
  • 02-20-2008 4:37 AM In reply to
    Would it have to be a Beo5 or could a Beo4 do a similar job since it will be using the IR blaster I guess I could choose Sony DVD player from the list?
  • 02-20-2008 4:42 AM In reply to
    chrisped:
    Both remote works ofcourse ;-)
    But Beo5 is better to use in my opinion....
  • 02-20-2008 4:51 AM In reply to
    This is really brilliant stuff especially since I have a nice big NAS serving up movies and pictures via UPnP to my PS3. My only wish would be that the PS3 could upscale video from UPnP streaming and not just DVD discs.
  • 02-20-2008 6:07 AM In reply to
    • Trucker
    • Not Ranked
    • Joined on 04-22-2007
    • Denmark
    • Posts 33
    Is PS3 on the STB-controllerlist in the TV ?
    Or how do you control the PS3 with the beo4.Is it play, stop, rewind when playing Blue ray?
    Trucker
  • 02-20-2008 6:13 AM In reply to
    Trucker:
    Trucker
     Yes BUT you must buy Nyko remote and you can not use on/off
    You can buy it only from USA or eBay
     I have this: www.schmatrz.com and it much better
  • 02-20-2008 6:25 AM In reply to
    Anders,
    can you move through your music, pictures, etc... or does it only work with the movie menu?
  • 02-20-2008 6:30 AM In reply to
    Because I am not a gamer I have had no interest in the PS3. However now I am looking for a blu-ray player that has flexible outputs so that I can continue to use scart connection to my non-HD BV6-26. This would enable me to upgrade my DVD1 without forcing me to change the TV now.
    This is even better if you can control the darned thing with a beo4. Because I don't know this product at all can anyone explain the on/off switch thingy. You all, obviously, understand what is going on but I don't. Is the devise being talked about from schwartz an infra red on-off? which will work with an stb?
    Sorry for my ignorance but I have never owned a gaming machine.
    Barry BV6-26,BC2300,Beolab8000,4000,3500,2000,DVD1
  • 02-20-2008 6:51 AM In reply to
    Victor77:
    Anders,
    100% use
  • 02-20-2008 6:56 AM In reply to
    BarryAndrew:
    I bought PS3 only to use it as BD player, but ofcourse you can use it with music, photos etc
    The Schmartz gadget is a ir receiver same as eg Nyko, BUT he has made it so you can use on/off
    PS3 use Bluetooth to pilot the consol, so if you want to use a IR remote you must have this
    If I where you I should stick with DVD1 until you buy a full HD
  • 02-20-2008 7:15 AM In reply to
    • Luigi
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Figueres (Spain)
    • Posts 3,013
    Another interesting possibility can be OneRemote.
    Luis
  • 02-20-2008 7:22 AM In reply to
    not for that price
    schmartz cost 30 dollar and 50 with on/off function
  • 02-20-2008 8:19 AM In reply to
    The problem with waiting for the HD TV before you get the HD player is that you have to buy both at the same time. Getting one at a time enables you to get what you want which may be constrained with a double purchase.
    Does the one remote allow the same sort of access as the stb? In other words will it allow link room access? If I wanted the PS 3 and bought the one remote when its available in March would I need anything else or will that do the job?
    The one remote is more expensive but if it does the job then it looks tidier and the PS 3 does have a BL 4000 look to it.
  • 02-20-2008 9:02 AM In reply to
    • Trucker
    • Not Ranked
    • Denmark
    • Posts 33
    Hi Anders,
    I have a BV7 mrk III and I can`t find the PS3 in the puc-list.
    I want to hide the PS3 in a cabin and use the schmartz and beo 4. How do I do ?
    Trucker
  • 02-20-2008 9:21 AM In reply to
    Trucker:
    Hi Anders,
    Trucker
     If you buy IR from Schmartz you shall not use PS3 in STBlist. It will only work with Nyko remote
    You shall choose a Sony DVD player. I shall look wich one I have in my list when I come home from work
    Your dealer can update your BV7 with ir generator
