Hi.
Grease for plastic moving parts, what kind am I going to use. The name for the white grease used for players what is that.
Per
Hi Per,
This isn't white, but it is for plastics. You don't get much, but a little goes a long way.
Cheers,
Steve
Hi Steve
Thanks for the anserw, I will try to find some in DK.
nrhalne: Hi.Grease for plastic moving parts, what kind am I going to use. The name for the white grease used for players what is that.Thanks Per
Check the service manual on site for the particular item. The recommended lubricants are indicated.
Regards Graham
