Latest post 02-22-2008 3:05 AM by joeyboygolf. 4 replies.
Page 1 of 1 (5 items)
  • 02-19-2008 10:48 AM
    • nrhalne
    • Not Ranked
    • Joined on 05-13-2007
    • Denmark
    • Posts 18
    Grease for plastic parts.
    Hi.
    Grease for plastic moving parts, what kind am I going to use. The name for the white grease used for players what is that.
    Per
  • 02-19-2008 3:24 PM In reply to
    Re: Grease for plastic parts.
    Hi Per,
    This isn't white, but it is for plastics. You don't get much, but a little goes a long way. Smile
    Cheers,
    Steve
  • 02-21-2008 3:44 PM In reply to
    • nrhalne
    • Not Ranked
    • Denmark
    • Posts 18
    Hi Steve
    Thanks for the anserw, I will try to find some in DK.
     Per
  • 02-21-2008 6:41 PM In reply to
    Molykote, is what your looking for.Wink
  • 02-22-2008 3:05 AM In reply to
    nrhalne:
    Hi.
    Per
    Check the service manual on site for the particular item. The recommended lubricants are indicated.
    Regards Graham
