flamel: Is there somebody here to answer the other questions I have ?
- Is there an official & updated B&O list for STB-C code ?
- Is there a way using the Beo4 to know the current value of the entered code ?
- Is there a way to know the current STB-C chip version embedeed in the MX ?
- same with the version of the MX software? is there a way through remote control to display software version ?
- As a consequence is there a correlation between MX software & STB chip version to provide correct functioning ?
thanks in advance
regards
1. there is a list with the latest software, sorry I don't have it.
2. No
3.try to press TV, Menu, 0, 0, Go (or Play), you will see the tv software. Try using the arrow keys to reveal the STB softwareversion.
If it won't work, open the MX and look for the STB-C chip (an installation manual is on the site) The software version is printed on the chip.
Remember that each software release has it's own table of codes.
4. Yes, see point 3.
5. Have you checked if the infrared (wire) is functioning well? Does your Sagem has a led which will light up when your using the original remote?
By using the infrared-wire, this led on the Sagem has to work also. Even when the entered code is wrong.
