Latest post 04-29-2007 5:54 PM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 04-29-2007 9:18 AM
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    MCL 2 AV - Non B&O datalink connection
    Is there any way to run a 5 pin din connection into a 7 pin MCL 2AV input and "trick" the MCL2Av and MCL2P into accepting it?
    Confused
    I am looking to run an older Beogram with 5 pin din or use the phono output from a DVD player in another location as the input for rear speakers, but there is no 6 or 7th pin to pass the datalink information along.
    I can use the transceiver to activate the MCL2P - but cannot make it select the input I want!
    Any help, archives, FAQ, brochures or other information source appreciated!
  • 04-29-2007 2:51 PM In reply to
    Re: MCL 2 AV - Non B&O datalink connection
    Yes!! To select the sources with a Beolink 1000, you need the following commands:
    For the CD socket - SHIFT,RADIO,6
    For the Tape input - SHIFT,RADIO,7.
    A Beogram will need a RIAA amplifier to work, mind you.
  • 04-29-2007 3:10 PM In reply to
    • Xseries
    • Hampshire
    • Posts 433
    Most useful - but where do you find that sort of information?
    Good point about the Beogram - back to plan B for that one!
  • 04-29-2007 5:54 PM In reply to
    The voices keep telling me things!Laughing
    Actually I have collected a fair amount of silly facts over the years and have a number of useful manuals that I can look in! I am better at the slightly older equipment like MCL as I have a hybrid MCL system!
