Latest post 02-20-2008 12:10 PM by Lagom. 8 replies.
Page 1 of 1 (9 items)
  • 02-10-2008 6:57 AM
    • Lagom
    • Not Ranked
    • Joined on 04-18-2007
    • New Orleans
    • Posts 35
    Airport Express and Avant
    Hello,
    I can push music from iTunes to my Airport Express and listen through my BS4000 using Aux input.
    How do I then listen through my Avant?  I can listen through any linked speakers in the house, but not the Avant.
    I have the BS4000 and Avant in close proximity.
    Thanks for any assistance.
  • 02-11-2008 5:32 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Airport Express and Avant
    I know both Peter and Soundproof are a bit clever** when it comes to Apple - and we do have plenty of other Apple-Genius's on here.. (not sure what the plural of genius is.. sorry!)
    Anyone have any ideas on this?
    Lee
    Smile
    ** = whizzes actually..
  • 02-11-2008 8:28 PM In reply to
    • Lagom
    • Not Ranked
    • New Orleans
    • Posts 35
    I should add that I can listen to Radio and CD through the Avant, which I do during lengthy commercial breaks.
    I do not how to select Aux from the BeoSound 4000 on the Avant. Is there a way to select the current source, as I would from linked speakers?
    Thanks.
  • 02-13-2008 1:45 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    I'm assuming from what you've said that the Avant and BS4000 aren't actually linked together?
    If not, I recommend you do this, and then you can use the Avant's built in speakers.
     Weekly top artists:
  • 02-14-2008 6:59 AM In reply to
    Don't you mean BeoSound 4, and not 4000? Going by how I option programmed my BV8/Beosys6500, the TV is running things.
    To get AUX through the Beo4, you go into the list menu. I had to add ATAPE2, I believe. (At the office now). Hunt around, relative to the connector you use - and get the options right on the two?
    Not as knowledgeable about this as others here, but I think it's your BeoSound 4000 that has confused things.
  • 02-15-2008 1:42 PM In reply to
    • Alex
    • Posts 2,990
    Lagom may be correct in saying BeoSound 4000, which I believe was another name for the BeoSound Overture.
    Lagom, do you have a BeoSound with two sliding doors and a CD clamper in the middle + tape deck, or a BeoSound with a single large sliding door which moves up to reveal a CD bay and SD card slot?
     Weekly top artists:
  • 02-20-2008 12:09 AM In reply to
    • Lagom
    • Not Ranked
    • New Orleans
    • Posts 35
    Yes, I have the US version, BeoSound 4000 with the tape deck and sliding doors that also houses the CD clamper.
    I do not know the correct function/buttons to press on the Beo4 to pull up the Aux selection from the BeoSound 4000 through my Avant.  (I know there must be a method, as I can on all my other linked products in the home.)
  • 02-20-2008 2:41 AM In reply to
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    I have a BS4 with an Airport Express, connected to my Avant. I press A.AUX in the Beo4 list to listen to iTunes.
  • 02-20-2008 12:10 PM In reply to
    • Lagom
    • Not Ranked
    • New Orleans
    • Posts 35
    I got it to work today, but this time I did something different.
    I did not have the Aux output selected on the stereo.
    Aimed at the TV, I pressed AV, A.AUX and the stereo snapped on and music came from both BeoSound 4000 and Avant.  (They aren't in the same room, but I live in a warehouse and the remote is powerful enough to operate both.)
    Thanks for all of your assistance.  Mardi Gras is over so I had time to attend to these types of needs. :o)
