Latest post 02-16-2008 4:49 PM by jk1002. 9 replies.
Page 1 of 1 (10 items)
  • 02-09-2008 5:42 PM
    Beovision 8 is on the official NA website
    http://www.bang-olufsen.com/page.asp?id=430
    It doesn't have an integrated tuner which I think is awesome -> that means they can bring Beocenter 6 and BV7 32" as well.
    While I like both TVs much more on first impression, I will definitely take a look at the BV8 in the next few weeks.
    Cheers
    JK
  • 02-10-2008 12:35 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: Beovision 8 is on the official NA website
    The BV-8 has already reached the B&O stores in the US, you should be able to see one with no trouble if you're nearby.  Be fore you buy, make certain to go over the connections available, and be sure that your dealer has the SCART adaptors on-hand, or at least on the way.
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 02-10-2008 1:56 PM In reply to
    I am not sure how to connect my projector which I definitly would want to keep.
    I don't think it has a video out ..... not sure if that ML module adds that via scart, I think I read somewhere it is 2 way whatever that means.
    I don't need surround or multiple HDMI, I just want to be able to watch video through front row from my mac and maybe DVD through a BC2.
    Whoever buys one here in the US first, please post your experience. I am just glad that they came up with the no Tuner solution which should allow them to bring the rest of the TV line as well. Not sure why the BV7 32" upgrade to BS3 takes them so long, that would probably be more suitable for me.
    JK
  • 02-11-2008 1:01 PM In reply to
    • Russ
    • Posts 641
    From what you're saying with regard to the projector, you'll need to get something in the BS-3 family.  BV-8 has no video out at all, and really isn't intended for theatre use.
    Other than that, the picture is quite good, and I think the sound is really nice.  For its intended purpose it is a great piece.
    Russ
    McLean, VA USA
  • 02-12-2008 12:09 AM In reply to
    Russ,
    Just to confirm once again, does the BV8 have a sleep timer? I mean one that will turn the TV off as any regular bedroom TV (15-30-45-etc). I don't mean a built in clock function as in other B&) equipment.
    Seems a rational feature for a bedroom set.
  • 02-12-2008 9:59 AM In reply to
    One more question: Is ML standard or extra here in USA?
  • 02-12-2008 6:48 PM In reply to
    • beotex
    • Not Ranked
    • Joined on 04-20-2007
    • USA
    • Posts 32
    Anyone know what the price is?
  • 02-12-2008 8:47 PM In reply to
    • symmes
    • Top 200 Contributor
    • Joined on 04-21-2007
    • Freedonia
    • Posts 290
    Extra for the MasterLink module.
  • 02-13-2008 5:10 PM In reply to
    • Russ
    • Posts 641
    No Sleep timer that I can find.
     ML module is indeed extra, as is the Beo4/5.
     $3755.00
    ML Option looks to be $350.00
     Russ
    McLean, VA USA
  • 02-16-2008 4:49 PM In reply to
    Walked by a dealer today. I think price he said is 3950 plus around 400 for the module.
    It doesn't seem to have a video out, which is confusing to me as the tech spec says scart in/out and how would one connect a HDR if the video signal is not passed out via scart? Not sure though if that would be usable or not.
    Does anybody know if it can control the Apple TV, i.e. with fast scrolling? In the menu I saw only the Ipod remote. On the german forum somebody mentioned that one needs PUC Apple STB remote V01 from August 2007? Is this available in US? I would be all set If I can get the fast scrolling in Frontrow or Apple TV.
    I have to say it looks much better in real live then on picture. It matches very nicely with my Lab 3s. Stopped by afterwards at a best buy and looked at Sony but that ain't going to happen.
    Cheers
    JK
