I found these light strips at Conrad. quick and easy.
Everything seems to work now.
Although I do have a question...
My TV and light dimmers respond very well to the BL7000. (LX6000 tv).
I am not sure if it should be possible or not, but it seems my Beomaster 5500 and Beocenter 8000 will not respond to the BL7000. Is that a normal issue? In other words, should I upgrade to a BM7000? And if I upgrade, do all BM's 7000 have RDS?
Thanks again!
^NOTE TO MYSELF^: RTFM... OK, I found the trick... setup the BL to be able to connect to the BM and BV's...
